Converter DC-DC 12V / 5V 3A 15W with Micro USB
CPT Converter DC-DC 12V / 5V 3A 15W with Micro USB
Reference : 11759
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Here is a DC / DC converter, from 12V to 5V, and up to 3A output (15W), with pre-welded Micro USB cable.
This compact converter / regulator, cast in moisture-resistant epoxy resin, will give you a stabilized and clean energy source.
This converter is particularly useful when you want to place the Raspberry Pi in a mobile application, such as a car, for example. Or any other 12V DC source.
Main Features :
  • Mounting hole diameter: Ø 3.5mm
  • Pre-tinned terminations
  • Input voltage: 8 - 20V DC
  • Output Voltage: 5V DC
  • Output Current: 3A (max) / 15W
  • Operating Temperature Range: -10 ° C ~ + 45 ° C
  • Overload, over-voltage, undervoltage, overheating and short-circuit protection
  • Cable length: 13cm
  • Micro USB cable length: 30cm
  • Molded plastic chassis
  • Dimensions: 46x27x14mm
  • Weight: 45g
  • Black color
- Example of connection to the Micro USB of a Raspberry Pi 3 (not included) -
Output voltage (V)5.0
Input voltage (V)12.0
3 reviews
Super
Je l'utilise pour alimenter un Raspberry Pi 3 à partir d'une alimentation de disque dur externe. Marche très bien.
This review has been posted for Converter DC-DC 12V / 5V 3A 15W with Micro USB
Produit conforme
Pas de problème pour ce produit bon marché.
Utilisé sur raspberry PI
Testé pour convertir une alimentation 12V secourue par batterie plomb pour un projet d'alarme sur raspberry PI . Fonctionne bien , à voir sur la durée .
