IBASSO DX90 HIFI DAP music player ES9018K2M x2 8GB 24bit / 192khz
Ibasso DX90 Baladeur HIFI DAP ES9018K2M x2 8Go 24bit/192khz
By buying this product you get 45 loyalty points
Reference : 8714
459,00 €tax incl.
382,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Let's not forget the sedentary, more expensive solutions.
Excellent player based on a double Sabre32 converter now very well known, this modern player combines an excellent touch interface, a compact format and an amazing audio quality.
With a surprising value for money, it is one of the major players in the DAP (digital audio player) scene and will serve as a high-quality digital source whether for nomadic or sedentary use.
Features:/ Strong>
  • Bit Perfect: Supports sampling rates up to 24Bit / 192kHz
  • DAC: One ESS Sabre32 ES9018K2M per channel
  • Headphone amplifier: OPAMP OPA1611 x2, 2 x buffer BUF634 by Texas Instruments +/- 5V
  • Display: -2.4 "IPS (320 * 240) Capacitive Touch
  • Digital Output Coaxial: 24Bit / 192kHz
  • Analog outputs: 3.5mm jack for headphones and line output
  • USB: OTG (On The Go) function to use USB external storage
  • Physical buttons: 3 buttons (Rewind, Play / Pause, Forward)
  • Volume: digital control 256 steps
  • Memory: 8 GB internal + support SDXC, SDHC and MicroSD up to 2 TB
  • Play: Gapless
  • Equalizer: 5 presets + "Custom"
  • Gain: 3 settings per switch (to best fit all headphones)
  • Supported formats: APE, FLAC, WAV, WMA, AAC,ALAC, AIFF, OGG, MP3
  • Battery: removable compatible I9300 2100mAh
  • Battery life: 8.5 hours
  • Charging time: 3h with AC adapter / 5.5h via USB
  • Dimensions: 64 x 100 x 17 mm
  • Weight: 140 g
Specifications:
  • Line Output:
    • Frequency response: 17Hz ~ 20KHz + / -0.1 dB
    • Noise Ratio: -119dB + / -1dB
    • THD + N: 0.0015%
    • Crosstalk: 115dB (1kHz)
    • Output Level: 1.7V rms (1kHz 0dB)
  • Headphone output:
    • THD + N: 0.0015% (32ohm charge)
    • Output Level: 1.3Vrms (Low gain), 2.0Vrms (Mid gain), 2.8Vrms (High Gain)
    • S / N: -118dB +/- 1dB (Low gain), -116dB +/- 1dB (Mid gain), -115dB +/- 1dB (High Gain)
    • Crosstalk: 75 dB (1 kHz 32 ohms)
    • Output Impedance: <0.1ohm
Accessories :
  • USB cable: load and data
  • Coaxial cable
  • Screen Protectors
  • Black Silicone Case
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_10.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_11.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_9.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_13.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_14.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_15.jpg
In the package:
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_16.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_12.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_7.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_6.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_5.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_3.jpg
https://www.audiophonics.fr/images2/8714/8714_ibasso_DX90_dap_baladeur_esssabre9018_2.jpg
5 reviews
Excellent
upgradé en version 2.2.0 en remplacement d'un cowon J3,remarquable mais dépassé et après un court rodage, sur du Classique ou du Jazz et en fichier 24 bits et 96 khrz,
le résultat est Sidérant...
en combinaison avec des Shure 535 le son
est parfaitement naturel.
On n'y est sans effort de concentration.
Aucun concurrent dans cette game de prix.
surement le meilleur achat nomade, sauf a dépenser 2 à 3 fois son prix.
A écouter sans faute avant tout investissement conséquent.
This review has been posted for IBASSO DX90 HIFI DAP music player ES9018K2M x2 8GB 24bit / 192khz
Excellent
Passage d'un iPod Classic au iBasso, que du bonheur. Je redécouvre ma musique. Je l'utilise avec un ampli casque Headstage Arrow et un AKG K702 ou Grado 80. Service Audiophonics au Top. Seul bémol l'interface de navigation un peu moyenne.
Excellent
Apres plusieurs essai , intras, casque planar bien connu, et direct sur l ampli depuis la sortie ligne...
Je suis totalement séduit , meme constat, scene sonore large, neutralité qualités de sons évidantes
qualité perçu de meme , a reconnu un micro SD 128gB sans broncher
Je ne peux que le recommander
d'abord 5 étoiles pour le service proposé par AUDIOPHONICS!!! vente en ligne très pro mais avec un service clientèle quasi de proximité (info disponibilité produit, livraison rapide etc...)
le produit :
encore un très bon rapport qualité prix pour ce DAP , on frôle sans doute le ht de gamme mais à un tarif raisonnable
de plus vous bénéficierez maintenant de la fonction DAC qui est implémentée, et driver dispo !!!
très belle finition, package interessant ( housse silicone fournie et films!!) connectiques ...
amplification : suffisante pour un produit à vocation nomade , un ampli de type AMP911 permettra de driver des casques plus gourmands
multi compatibilité fichiers DONT DSD ( .dsf)
mémoire externe ras!! 64 go et plus
pour conclure le SON: signature équilibrée , micro détails , dynamique , scène sonore, tout est bon ou très bon sur ce DAP
( mes anciens dap: COLORFLY C4 , DX50)
Je viens de recevoir ce DAP et ne regrette pas mon achat.
Je l'utilise avec des Westone W40.
La qualité sonore est au rendez-vous avec une scène sonore extrêmement large, un niveau de détail époustouflant et une belle neutralité. Mes W40 y sont bien sûr pour quelque chose mais je note un énorme progrès en comparaison aux lectures des mêmes fichiers FLAC sur HTC One/Poweramp ou PC/foobar2000). Je découvre encore des détails et les voix ont pris une nouvelle dimension en venant plus sur le devant de la scène.
Je complèterai mes impressions sur TN et head-fi.
Enfin, je veux souligner l'excellent niveau de service d'Audiophonics : je trackais la disponibilité du DX90 et ai toujours eu des réponses rapides et honnêtes à mes questions répétées.
Et quand j'ai été informé hier de la disponibilité du DX90, le process de commande s'est déroulé on ne peut mieux et j'ai été livré moins de 24h après avec l'option TNT! Bravo.
Merci.
Je reviendrai pour de potentiels futurs besoins et ferai savoir ma satisfaction sur le net :-)
