Xuelin IHIFI770 HIFI DAP 24bit/192khz WM8740 8go
Reference : 9218
169,00 €tax incl.
140,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Xuelin IHIFI770 HIFI DAP 24bit / 192khz WM8740 8GB Portable Music Player
The IHIFI770 is designed around the high efficiency Wolfson WM8740 converter.
This player has a large format touch interface, a very nice ergonomics, as well as an astonishing musicality.
Surprisingly good value for money, it is easy on the scene of the DAP (Digital Audio Player) and will offer you a high quality digital source.
Characteristics:
  • Supports sampling rates up to 24Bit / 192kHz
  • DAC: WM8740 24Bit
  • AOP (Amplifier): AD86565 Low Noise
  • Integrated Headphone Amplifier MAXIM CMB1907A
  • Touchscreen
  • 2 Analog outputs (2 different sounds): jack 3.5mm for headphones
  • USB: OTG function (On The Go) giving the possibility of memory extension
  • Memory: 8 GB internal
  • Memory expansion for MicroSD card (not included)
  • Supported formats: APE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3
  • Battery: Approx. 13h
Specifications:
  • Frequency response: 20Hz ~ 20KHz +/- 0 to 2.5dB
  • Noise Ratio: 105dB
  • Output Level: 3.6V
  • Impedance and output level of headphones: 120mw + 120mw / 32 ohm
  • THD + N: <0.004% at 1kHz
  • Dimensions: 64 x 117 x 8.8mm
  • Weight: 103 g
Accessories:
  • USB cable: load and data
  • Leather Case
[Img-8692-left-thickbox_default]
ihifi
ihifiihifi770
