FURUTECH FC-62 Digital Interconnect Cable µ-OFC 75 Ohm Ø6.3mm
FURUTECH FC-62 Digital Interconnect Cable µ-OFC 75 Ohm Ø 6.3mm
Reference : 11147
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
This balanced FURUTECH FC-62 balanced modulation cable made of multi-stranded Alpha-processed OFC copper is a quality solution for connecting your DAC or any other digital audio and video source.
Thanks to the surface treatment α Alpha, exclusive to the Japanese brand, digital precision is not at the expense of timbres. The Alpha treated copper braided sheath provides the most effective protective screen. The FURUTECH FC-62 is thus a beautiful balance offering definition and natural harmonics to the listening.
A well built 75 Ohm digital cable designed by a Japanese brand well known for its seriousness which is in line with FURUTECH productions.
The high quality of the mechanical assembly offers a very convincing result when listening. A digital cable that will be in perfect harmony with high quality RCA copper plugs.
Features:
  • 1 core with 19 conductors (surface treatment α Alpha) 0.2mm OFC Copper.
  • Insulation: Thin layer of foamed Polyethylene.
  • Shielding: 0.12mm µ OFC aluminium wire braid (surface treatment α Alpha).
  • Wrapping : Flexible PVC hose (blue).
  • Maximum resistivity: 0.0327 Ω/ M.
  • Outer diameter: 6.3mm (20 AWG).
Diameter (mm)6.3
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingYes
Section (mm²)2.00
Ground / ShieldingYes
3 reviews
EXCELENTE CABLE
Recomiendo esta tienda, por ser un 10, y también este cable..Sin tener que recurrir a materiales exóticos, el rendimiento me ha sorprendido gratamente. Furutech no decepciona, calidad incontestable.
This review has been posted for FURUTECH FC-62 Digital Interconnect Cable µ-OFC 75 Ohm Ø6.3mm
Tres bon câble
Coaxiale d'excellente qualité. En terme de rapport qualité prix, difficile de faire mieux.
Je l'utilise entre un CD723 Phillips et un DAC Audio GD NBF 2.32...Et ça marche très bien. Un son précis, une bonne dynamique et de la vitalité.
Bref tout est là !
Très bon !
Utilisé pour confectionner un câble coaxial avec connecteurs bnc d'un côté et jack de l'autre pour relier un digione allo et un chord mojo. Aucun problème pour la soudure des connecteurs, il est assez souple et solide. Il "transporte" parfaitement le signal numérique vers le dac !
