SOMMERCABLE CARBOKAB 225 Interconnect AES/EBU cable shielded OFC 2x0.25mm² Ø 7.6mm
Reference : 9928
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Symmetrical, high-end, with smoothed conductors
SOMMER CABLE - SC-CARBOKAB 225
It is every year ...
that emerge new processes of development of studio cables. The current trend is towards the use of solid conductors, having better conductivity due to the homogeneity of the surfaces, and a wiring technique that improves the audio qualities. Theoretical facts, because a solid conductor also has disadvantages: it is hard, so that a slight bending of the cable can already damage the insulation; the ductility is restricted, and each curvature produces a crushing of the outer layers. Without underestimating the traction forces on the connection terminals. This is why Sommer Cable has designed the SC-CARBOKAB 225 cable, characterized by a special process of smoothing the conductive surfaces: a very dense carbon layer coats the concentrically braided cores. The conductivity is thus comparable to that of solid wires, but the conductors are highly flexible and have excellent and durable technical characteristics. Because of these qualities, the SC-CARBOKAB 225 cable guarantees an absolutely linear and faithful acoustic reproduction up to a distance of 200 meters. Remarkable is also the shielding with 100% covering (fleece AL + tress Cu), to counter the high density of peripheral electromagnetic perturbations of the studios (effects devices, computers, synthesizers, etc.). Special HD-PP mixing insulation guarantees very low capacitive values. With this cable, you will be "State of the art" and will be able to spare you all the "esoteric" and tiring discussions!br>
ADVANTAGES:
  • Following the carbon smoothing process, audio qualities comparable to that of a solid conductor
  • Low capacity value due to high-end HD-PP insulation
  • Excellent shielding by Cu braid (with drain wire) and AL fleece
  • Excellent conductivity thanks to the use of copper without oxygen (quality 6)
USE:
  • Highly specialized technique for studio and installations
  • Broadcasting and broadcasting technology for mobile stations
  • High-quality hi-fi connection (red and white wire to terminal 1, separate shield)
Specifications:
Constitution(2LI2Y0,25mm2) (ST) CY
Envelope, diameterS-PVC 7.6 mm
AWG23
Conductor inside2 x 0.25 mm 2
Brass Cu per core65 x 0.07 mm
Insulation of the conductorHD-PP 1.55 mm
Protectionplaited copper braid 95% + fleece AL + drainage wire
Optical cover100%
Operating temperaturemin. -25 ° C
Operating temperaturemax. 70 ° C
Fire resistance per m0.22 kWh
Weight per m75 g
Packaging unit, packing unitper meter
Colorblack
Electrical Specifications:
Capacity metric cond./cond.46 pFMetric Capacity Screen / Display90 pF
Odometer Resistance, Conductor<78 Ohm
Resistance, shielding<10 Ohm
Resistance, insulation> 200 MOhm
Characteristic Impedance(+/- 2%) 110 Ohm
Diameter (mm)7.6
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingYes
Section (mm²)0.25
Ground / ShieldingYes
5 reviews
Amazing
This is the best cable I have made so far in my system (very low capacity measured ~50nF/m)
This review has been posted for SOMMERCABLE CARBOKAB 225 Interconnect AES/EBU cable shielded OFC 2x0.25mm² Ø 7.6mm
Utilise avec les NFXcc, constitue un excellent câble AES pour ma liaison Drive CD et Dac. Surclasse bien des cables spdif a plus de 200 euros....
Pour enfiler la bague de blindage de la XLR, il faut detresser la tresse de masse, enlever la feuille de blindage puis lisser les brins de masse le long du câble pour pouvoir faire coulisser la bague en butée de la gaine du câble.
Pas encore rodé, mais constitue une excellente liaison AES entre Drive CD et Dac, , avec les XLR NC3 XCC. Pour moins de 30 euros pour un câble de 1m, surclasse des liaisons SPDIF à plus de 150 euros.... Voire plus de. 200...
Très bon câble
Testé (assemblé selon les prescriptions de Sommercable,les deux câbles conducteurs sur le point chaud,tresse à la masse des deux cotés) entre une platine vinyle et un préamp et entre un lecteur CD et un ampli intégré,c'est très bon.Un son vivant,frais,plein de détails.
Très bon produit
De par sa conception: supérieur au Binary 234 MK2 du même constructeur que j'utilisais en AES/EBU pour transmettre les signaux audio numériques sur plus de 4 m.Apporte beaucoup plus de définition au signal (il a été conçu pour les studios et le Broadcast , et pour des distances importantes.);
