MiniDSP BOX 2x4 Audio Processor USB 2 to 4 channels unbalanced
MiniDSP BOX 2x4 Audio processor USB 2 to 4 channel Unbalanced
4.2 / 5
Reference : 8270
119,00 €tax incl.
99,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
MiniDSP 2X4 HD Interface - B Revision
IIR digital filter / DAC 24bit 96Khz
The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 192khz DAC (digital / analog converter) & asynchronous USB Audio Class 2.0 input. Like many other miniDSP devices, 2x4 provides powerful, accessible tools to implement a digital filter (IIR Butterworth / Linkwitz Riley 6 to 48dB) and a parametric equalizer. It will suit audiophiles who want to set an effective correction on a pair of stereo speaker. The device can also be used to manage multiple subwoofers in a home theater setup.
In addition to its digital input, the 2x4 in miniDSP has a stereo analog input on RCA connector for connecting another Hi-Fi device with analog output. Such as a turntable via a RIAA box, or any other analog source. It is a great accessory to centralize the whole installation on a single pair of speakers, while enjoying a correction / filter that extends to the entire chain.
Interface presentation
Plug-in miniDSP 2x4 HD
Audio processor
The 2x4 features a 28 / 56bit floating-point Analog Devices audio processor. The latter allows digital audio calculations as well as control via the USB interface in real time.
The MiniDSP 2X4 provides a complete solution with USB & analog inputs, filtering and parametric EQ.
Gain
Revision of the modelB
DSP engine28 / 56bit
DAC / ADC24 bit 48kHz
Connectivity StandardAsymmetric
analog inputAsymmetric, switchable with jumper 0.9Vrms and 2Vrms
analog outputsUnbalanced: Max 0.9Vrms changed to 2V (see manual)
Digital Input / OutputMicro-USB (I2S interface)
capacitorsNichicon
Volume ControlLocation potentiometer
PilotUSB Plug & Play with real-time software setup
Dimensions75 x 75 mm
Power supplyJack DC 5.5 / 2.1
Package Contents
Interface miniDSP 2x4HDx1
12V adapter plug UK / EU / US / AUx1
shielded USB cablex1
Code to download the plug-in 2 x 4x1
Max sampling rate96kHz
11 reviews
Excellent résultat avec enceintes large bande
Utilisé pour corriger la courbe d'enceintes TQWT avec HP Supravox large bande type RTF215 Résultat bluffant après seulement quelques mesures avec logiciel REW. Correction et transfert vers le minidsp facile moyennant un nécessire apprentissage. Bien plus efficace que n'importe quel filtre passif. Je recommande.
This review has been posted for MiniDSP BOX 2x4 Audio Processor USB 2 to 4 channels unbalanced
juste génial
Bon, c'est vrai qu'entre la sensibilité assez faible et les pertes générées par les filtres, on peut facilement chuter d'une dizaine de dB en sortie d'ampli. D'où l'intérêt des enceintes à haut rendement...
Pas de correction de phase non plus (sinon il faut prendre des boitiers supportant Dirac Live)
A part ça, pour ceux qui sont encore en analogique (en sortie des sources), c'est juste terrible.
Je l'utilise juste pour de la correction de pièce, et même si ce n'est pas indiqué dans le manuel, vous disposez de 12 PEQ (6 en entrée et 6 en sortie), ce qui est largement assez pour lisser les bosses et les creux sur le courbe de réponse.
Et que l'on ne vienne pas me dire que la double conversion (A/D puis D/A) fait perdre de la qualité au signal, alors que vous allez linéariser votre courbe de réponse dans des proportions allant jusqu'à plus ou moins 10dB... Restons sérieux....
Il a tout d'un grand
Je l'utilise pour contrôler la partie grave d'une enceinte, un HP de 38cm Fres : 27HZ ..... Adieu les énormes bobine à air et les condos coûteux, les filtres pour booster une caisse un peu trop petite etc..... Ca se pilote très bien et ça marche, que demander de plus à ce prix! Faites l'essai c'est top!
Produit bien imaginé , mais ...
J’avais acquis ce produit dans l’espoir de bénéficier d’un égalisateur graphique. Malheureusement le plugin ne fournit qu’un égalisateur paramétrique limité. Dommage.
Le service de Audiophonics est impeccable et le retour a été accepté sans problème .
"LE" Filtre 2 voies stéréo
Utilisé comme filtre actif sur une sono maison, c'est parfait!
Avec le plugin 2x4 advanced Il y a tout ce qu'il faut pour une enceinte 2 voies:
+ 2 filtres crossovers par sortie (Low pass / High pass)
+ 5 equaliseurs paramétriques par voie d'entrée
+ 5 equaliseurs paramétriques par sortie
+ 1 contrôle de niveau par entrée
+ 1 contrôle de niveau + inverseur de polarité + retardateur + compresseur/limiteur par sortie
Ça sonne propre, ça fait ce qu'on lui demande. On peut presque tout corriger. Avec le micro de mesure Dayton UMM-6 (j'imagine que le UMIK est bien aussi) et REW on peut aussi tout mesurer et vérifier la pertinence des corrections. LE TOP!
