ELECAUDIO PI-26GC Connector IEC Carbon Gold 24K 3μ Ø19.8mm
ELECAUDIO PI-26GC Power Plug IEC Carbon Gold Plated 24K 3µ Ø19.8m
3.5 / 5
Reference : 6844
39,90 €tax incl.
33,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
This high-end IEC connector from ELECAUDIO,PI-26GCis distinguished at first glance by its body Aluminum and carbon plating.
The head of the connector takes advantage of an alloy Fiberglass / Nylonfor its dielectric and mechanical qualities. Contacts are copper alloynon-magnetic one-piece and cut in the mass, on which is applied a plating Gold 24K.
This new chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
Its integrated clamping ring and anti-tear reducer allow the PI-26GCto receive and maintain well-centered cables of large section.
All metal parts, including the contact and ground poles, have benefited from a plating Gold 24k over 3μ thick .
This plating over the entire surface of the contacts is more resistant and better conductor than the standard gold plating, and is thus more resistant.
The internal connection terminals also deserve attention: They are equipped with large fixing screws and therefore do not require any soldering, they are able to receive large diameter conductors, which they hold firmly on a surface of special contactvery broad.
Finally, we will appreciate the small diagram directly engraved within the socket, which gives information on the optimum length of cable to be stripped. Since you are told that nothing has been left to chance ...
Specifications:
  • Body: Aluminum + Carbon plating
  • Head: Fiberglass and Nylon
  • IEC 3 plugs Screw-in contacts (BTR screws)
  • Plating:Or 24k 3μ
  • Maximum Driver Section:16mm²(4.5mm of Diameter)
  • Cable Diameter: from 12.5mm to 16.5mm(up to 19.8mm without ring)
  • Reducer available separately for cables of small sections (7.5 to 12.6 mm)
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 103 mm
  • Diameter: 40 mm
  • Weight: 110g
ELECAUDIO PI-26GC Prise Secteur IEC Carbone Or 24K
PI-26GC with reducer PI-26GC without gearbox
http://www.audiophonics.com/images2/6843/6843_PS-26GC_4.jpg
https://www.audiophonics.fr/images2/6843/6843_PS-26GC_5.jpg
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Cable schematics
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
2 reviews
Pas terrible
Connexion dans la prise de l’appareil approximative n’offre pas un bon contact,au niveau son elle est assez claire dégraissant légèrement le grave avec des sans grande matière.
Hormis la prise en aluminium on est loin de la qualité de connexion et sonore d’une Furutech
This review has been posted for ELECAUDIO PI-26GC Connector IEC Carbon Gold 24K 3μ Ø19.8mm
Excellent rapport qualité / prix !!
Elle rivalise largement à tous points de vue avec des prises du même acabit qui coûtent quatre fois plus chers ... Bravo !
