FURUTECH FI-C15 (G) Gold plated Copper IEC Connector Ø16mm
FURUTECH FI-28 (G) Gold plated IEC Connector IEC Ø 17.5mm
Reference : 12022
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
FURUTECH FI-C15 (G)
- Connector IEC Slim Design-
Designed primarily for LINN, Devialet or even McIntosh amplifiers with hard-to-access IEC plugs, these Furutech FI-C15 (G) connectors offer a finer design for easier connection.
The quality is not sacrificed since the conductor is in Pure Gold Co plated α (Alpha) 24k allowing an excellent conductivity of the signal. The connector body is made of nylon / fiberglass for added strength.
The alpha processing consists of 2 steps:
  1. Cryogenization of metals by -250 ° C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
  2. Submission of these same metals to a pmagnetic fields created by means of magnets arranged in annals and whose attraction force is constantly controlled so as to leave no magnetic residue at the end of the treatment
TECHNICAL CHARACTERISTICS
  • Conductor: Pure gold plated copper α (Alpha) 24k
  • Body: Nylon / Fiberglass
  • Cable Diameters Accepted: 6.6mm to 16mm (3.5mm² / 12AWG max)
  • Amotion and fixing polycarbonate cable + screws
  • Mounting: Screw
  • Dimensions: 22 x 30 x 82.2mm
Max cable diameter (mm)16.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)N/A
3 reviews
Prise
Super, accepté du 2,5mm voir 3,5mm diamètre du câble. Par contre bien serrer le fil de mise a la terre car la pastille de vis n a pas beaucoup de surface
This review has been posted for FURUTECH FI-C15 (G) Gold plated Copper IEC Connector Ø16mm
excellent produit
Très bonne prise fabrication très sérieuse, je confirme ce qui est mentionné dans l'avis précédent il faut souder le fil de terre sur une petite cosse qui est fournie avec la prise mais qui n'apparaît pas sur les photos, pas très compliqué quand on possède un fe à souder
Trés bon modéle!
J'ai acheté ce connecteur pour remplacé le modèle "Elecaudio LI-24GB" qui me donnait des faux-contacts.
Alors ce connecteur Furutech est facile a utilisé, il s'emboite agréablement bien dans une embase IEC C14, il est bien pensé, et il utilise de bon matériaux. remarque: le câble de terre nécessite un point de soudure.
La différence de qualité entre Avec Elecaudio est très net...
