Très bon produit et facile au montage.
Cordialement
Power connector Schuko Gold plated 24k 3µ Ø 16.5mm Crystal
The Schuko PS-24GC reference plug is distinguished at first glance by its transparent nylon body with impeccable finish and ideal proportions. This chassis can accommodate the most sophisticated cables whose diameter is often incompatible with conventional mains sockets.
With an insertion ring limiting the diameter to 16.5mm, supported by a flexible rubber cable clamp that completes the integration, the PS-24GC easily accommodates cables with a large cross-section. All the metal parts, in particular the contact and earth poles, were plated with 24k gold over 3µ thick. This full contact surface plating is stronger and better conductive than standard gold plating and is therefore more resistant.
The internal connection terminals also deserve special attention: Equipped with large fixing screws, and therefore requiring no soldering, they are able to receive large diameter conductors and ensure a firm hold over a particularly large contact surface. Finally, we will appreciate the small diagram directly engraved in the socket, which gives information on the optimal length of cable to strip. Since you are told that nothing has been left to chance...
Connector type | Schuko connector 3 contacts |
Connection type | To screw (BTR screws) |
Maximum conductor section | 16mm² (4.5mm diameter) |
Plating | Gold 24k 3µ |
Maximum cable diameter | 16.5mm |
Voltage / Current | 250V 16A |
Total length | 89mm |
Diameter | 38mm |
Color | Transparent |
Max cable diameter (mm) | 16.5 |
Mounting type | To screw |
Connectic | Male |
Connector | PLug CEE 7/7 |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Rated current (A) | 16.0 |
Average votes 4.9 / 5 17 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Roland B.
Cédric N.
Arnaud F.
Pierre A.
