ELECAUDIO PS-26GC Plug Sector Schuko Carbon Gold 24K 3μ Ø16.5mm
ELECAUDIO PS-26GC Schuko Power Plug Carbon Gold Plated 24K 3µ Ø16
4.3 / 5
Reference : 6843
39,90 €tax incl.
33,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
The high-end Schuko plug from ELECAUDIO, the PS-26GC is distinguished at first glance by its body Aluminum and carbon plating with impeccable finishing and ideal proportions. This new chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
The head of the connector takes advantage of an alloy Fiberglass / Nylon for its dielectric and mechanical qualities. Contacts are non-magnetic copper alloy in one piece and cut in the mass, on which is applied a plating Gold 24K.
Its integrated clamping ring and anti-tear reducer allow the PS-26GC to receive and maintain well-centered cables of large section.
All metal parts, including the contact and ground poles, have benefited from a plating Gold 24k over 3μ thick.
This plating present on the whole surface of the contacts is more resistant and better conductor than the plating Standard gold, thus the PS-24GC is all the more immunized against any form of oxidation.
The internal connection terminals also deserve attention: They are equipped with large fixing screws and therefore do not require any soldering, they are able to receive conductors of large diameter which they provide a maintis firm on a particularly wide contact surface.
Finally, we will appreciate the small diagram directly engraved within the socket, which gives information on the optimum length of cable to be stripped. Since you are told that nothing has been left to chance ...
Specifications:
  • Body: Aluminum + Carbon plating
  • Head: Alloy Fiberglass and Nylon
  • Schuko plugs 3 Screw-in contacts (BTR screws 2mm)
  • Plating:Or 24k 3μ
  • Maximum Driver Section: 16mm²(4.5mm of Diameter)
  • Cable Diameter: from 12.5mm to 16.5mm(up to 19.8 mm without ring)
  • Reducer available separately for cables of small sections (7.5 to 12.6 mm)
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 103 mm
  • Diameter: 40 mm
  • Weight: 124g
PS-26GC with reducerPS-26GC without reducer
https://www.audiophonics.fr/images2/6843/6843_PS-26GC_4.jpg
https://www.audiophonics.fr/images2/6843/6843_PS-26GC_5.jpg
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Cable schematics
Max cable diameter (mm)20.5
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
4 reviews
A essayer sans arrière pensée!
C'est la FURUTECH FI-E11-N1 (G) qui m'a incité a chercher une nouvelle schuko (Cf. commentaire), j'ai après échange avec l'équipe Audiophonics jeté mon dévolu sur cette Elecaudio.
Quelle surprise à l'écoute, le sentiment d'un robinet ouvert, de plus de tout, la musique coule sans agressivité, son plein, dynamique et transparent. Une belle association avec le Belden 19364.
This review has been posted for ELECAUDIO PS-26GC Plug Sector Schuko Carbon Gold 24K 3μ Ø16.5mm
Pas convaicu
Connecteur de bonne fabrication avec sont corps alu carbone,mais niveau son je la trouve moyenne ,les timbres du médium sont blanc sa manque de chaleur de vie en général. Pourtant leur connecteurs leurs cables sont souvent chaleureux,rond,la c est le contraire .Le son est plus basé dans le haut du spectre conviendra mieux pour un cable rond ,chaleureux pas avec un cable équilibré .Ne convient pas a mon systéme .
Excelent product for an still afordable price
Easy to assemble and fits any descent cable. Very nice aesthetics is a plus
prise carbone
proche de la yarbo mais moins chère, serrage cable avec de grosses vis, belle finition
