ELECAUDIO RS-34GW Schuko Type E/F Power Connector 24k Gold / SIlver Plated Ø16.5mm Bordeaux
ELECAUDIO RS-34GW Wine Schucko Power Plug 24k Gold/SIlver Plated Ø16.5mm
Reference : 10026
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
These Hi-Fi power connectors where developed in France to be used with the most sophisticated power cables in the market.
The body with an exclusive and modern design was built with high pressure. His composition, 30% Fiber Glass, and 66% Nylon, can even support industrial environments, resistant to high temperatures, impacts and crushing.
We can even call these power connectors as a hybrid, an industrial quality adapted to a Hi-Fi use.
With his uniform 4mm body injection for effective vibration and resonance dampening you can use it in many ways.
Thanks to a twist grip clinch claw for cables diameters from 13.5mm to 16.5mm you can have a wide option of cable diameters to create the perfect Hi-Fi grade power cable. This clinch claw will allow the cable to stay always centered no matter the cable diameter. (Diameter Reducer for ELECAUDIO RS-24, RS-34, et RI-24 Connectors is avaible lower in this page)
All the connectors are screw Stainless steel for maximum strength.
The head of the connector also benefits of the alloy Fiberglass / Nylon for its dielectric and mechanical qualities. Contacts are copper alloy non-magnetic in one piece and machined from solid, which is applied on Silver/24K gold plating.
Specifications:
  •    Body : 30% Glass Fiber & à 66% Nylon
  •    Screws: (BTR 2mm screws)
  •    Plated: Silver/ Gold 24k
  •    Maximum conductors section: 15mm² (4.5mm diameter)
  •    Cable diameter : de 13.5mm à 16.5mm
  •    Tension/Voltage : 16A / 250V
  •    Total length: 103.7 mm
  •    Diameter: 42 mm
  •    Weight : 92g
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
2 reviews
Simple et efficace
Facile à mettre en oeuvre, de bonne qualité et bien finie..
This review has been posted for ELECAUDIO RS-34GW Schuko Type E/F Power Connector 24k Gold / SIlver Plated Ø16.5mm Bordeaux
tres bon produit !
bonne prise de trés bonne qualité! le corp est trés rigide , ce qui facilite le maintient de cables de gros diamètre (yarbo 8000 ! )
couleur élégante et plutot discrete !
Bon RQP !
utilisées sur rallonge sur barrette , platine vinyle , boitier d'alim séparé, dac oppo ! excellent avec le yarbo !
