SMSL AD18 V3.1 Digital Amplifier Bluetooth NFC TAS5342A 2x 70W + Subwoofer out / 4 Ohm
SMSL AD18 V2.2 Digital Amplifier NFC TAS5342A 2x 65W + Subwoofer out / 8 Ohm
The SMSL AD18 V3 is the FDA Full Digital Amplifier par excellence. Providing high-definition melodic sound from both Bluetooth 4.2 and 242kHz USB 24bit, it also has a subwoofer active subwoofer output that delivers unbeatable stereo audio for even speakers.
4.7 / 5
Reference : 11498
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
SMSL AD18 V3.1
FDA Amplifier NFC TAS5342A 2x70W Subwoofer Output 4Ω
SMSL AD18 Amplificateur FDA
The SMSL AD18 comes back to us in V3 version with this time an integrated Subwoofer output, and the possibility to adjust the brightness of the screen (DIMMER). The Subwoofer output is accessible via the 3.5mm jack port at the base for Coaxial / Optical input. As shown in the diagram below:
smsl ad18
Despite the fact that it is the same connector, you can use the Coax / OPTI1 input and the Subwoofer output simultaneously with a jack to RCA cable (mixed or female) like this one:
smsl ad18
You can use this adapter to use coaxial and subwoofer : 3.5mm stereo male to 2x RCA female jack adapter cable 15cm
This adapter is also compatible: 3.5mm stereo male to RCA female stereo jack adapter
You can also use this adapter if you need only coaxial intput :
Jack to RCA adapter Coaxial AD18
SMSL AD18 is part of the new generation of FDA Full Digital Amplifier. It uses the high technology TAS5508C and TAS5342 chips using Texas Instrument's Digital Pure Path process. With a compact design it will bring a high resolution for the music lover who wants to combine compactness and high audio quality.
This amplifier has the characteristic of being a "Full Digital" i. e. that the S/PDIF or USB signal is converted to I2s and then directly amplified by the torque TAS5508C and TAS5342. The path of the digital signal thus simplified allows an astonishing quality of restitution of this category of apparatus.
The Bluetooth BT4.2 NFC Bluetooth format input allows you to take advantage of the qualities of the SMSL AD18 by offering better quality wireless playback for compatible iPad, iPhone, iOS, tablets and Android smartphones. (maximum distances 10m in close surroundings without obstacles).
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass tuning, treble, etc.).
It will be the ideal companion for any digital wireless or cordless source. Its ergonomics and compactness are not inconsiderable assets, to which is added its versatility thanks to its 1.44 colour TFT display, which precisely indicates each function.
To connect a coaxial cable to the AD18's Coaxial input in 3.5mm Jack format, you can use this compatible adapter: 3.5mm male mono to female RCA jack adapter.
Warning: AAA battery for remote control not included. Available here: AAA GP Battery.
SPDIF InterfaceCS8422
USB InterfaceVT1620A (16bit 44.1kHz-192kHz, 24bit 44.1kHz-96kHz)
DisplayColor Screen TFT 1.44"
4.2 NFC Bluetooth InterfaceCSR A64215 A11u
FDA ControllerTAS5508C
Amplifier moduleTAS5342A
Amplifier power2 x 70W at 4Ω (@THD 10% @24V)
2 x 40W at 8Ω (@THD 10% @24V)
Headphone amplifier chipMAX97220A
Double Op-AmpNE5532
THD0.04%
Frequency response18Hz - 22kHz
Digital equalizer7 positions (correction +/- 8dB)
Connectors
Digital inputsS/PDIF Optical Toslink
Mini Coaxial Optical
Micro USB-B
Digital inputsJack 3.5mm Stéréo
BluetoothBT4.2 (SNR 90dB)
HP OutputsScrew terminals, supports banana plugs 2.5mm
Subwoofer Output (SW)Jack 3.5mm "COAX / OPTI1" (unfiltered output)
Headphone outputAt 32Ω 53mW @ THD 0.04%
Power supplyPower supply included 24V 6.75A
Jack DC 5.5/2.5mm
(Linear power supply 24V 4A available)
(Do not supply with more than 24V)
Dimensions172 x 51 x 85mm
Weight1485g
AccessoriesMicro USB Cable
Power supply
Bluetooth Antenna
User manual
Remote
Remote controlIf remote controle does not respond, press the "A" key.
smsl ad18
smsl ad18
smsl ad18
smsl ad18smsl ad18
InputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
OutputJack 6.35mm
Channel2 (Stereo)
Amplifier chipTAS5342A
Power (W)40.0
Remote ControlYes
199 reviews
Étonnant
Vraiment étonnant le son sort de cette petite boîte D'accord je n'utilise pas l'alimentation fournie mais une alimentation audiophonics LPSU250 pourtant je pilote des JBL L65 Jubal pas facile a driver...alimenter par un très bon DAC ça fait des merveilles en Bluetooth également il y a moins de niveau forcément merci Audiophonics toujours au top sur le service et en plus vous pouvez trouver des connecteurs WAGO très efficaces pour raccorder vos fils d’enceintes
This review has been posted for SMSL AD18 V3.1 Digital Amplifier Bluetooth NFC TAS5342A 2x 70W + Subwoofer out / 4 Ohm
Bon ampli fda
Franchement, un rapport son/prix imbattable. Aucun bruit de fond, belle patate, bon son, franchement bien. Je ne suis pas de ceux qui parlent du son d'un ampli comme d'un grand vin. Je n'attends rien de plus d'un ampli que de faire ce qu'on lui demande. Il le fait parfaitement bien tant qu'on reste dans son terrain de jeu.
Smsl ad18
Je vous raconte mon histoire je possède depuis quelque temps un amplificateur yamaha As701 connu de tous. A ma grande stupeur je me suis rendu compte que le son numérique du smslAD18 était pour moi un niveau au dessus. Clarté du timbre des voies. Le yamaha est très bon mais le Smsl a un son plus chaud. Il sont connecté à mes vieilles Philips rh 2253. À l’écoute sur celle ci c’est le Smsl qui gagne le match largement. Ce qui me fait peur c’est sa durée de vie. Espérons quil ne souffriras pas d’obsolescences. Merci à audiophonic pour sa rapidité. Je pense à l’avenir rester sur du numérique avec le Smsl a2.a bientôt. Je recommande ce produit.
rapport qualité prix au top
j'en et deux utiliser sur diverses enceintes je l'ait testé sur des cabasse sampan 311 des sampan 310 des aviso aussi et des colonne jamo s 626 il se débrouille super bien et au vue se sont prix y-a aucun reproche à luis faire , je utilise pour le son de la TV en optique et pour jouer au jeux video , et le 2 emme dans une chambre sur des petite enceintes jamo bref , il et pas asses audiophile pour avoir le logo hi-fi mai bien des ampli plus cher sont même moins bon ^_^ en gros c'est moins bon qu'un naim nait 5 si !! 1600 euros mai c'est au dessus d'un denon pma 520 ae 400 euros !! donc pour 139 euros rien à dire
très bon rapport qualité prix
Oui l'écoute est bonne au vu de l'appareil et de son prix....mais il ne faut pas s'attendre à une qualité d'écoute bluffante non-plus. Les voix sont sombres, il subsiste un voile sur l'ensemble du spectre et les timbres sont très simplifiés. Il est difficile d'être objectif pour juger cet appareil de toute façon totalement hors catégories. Comment se plaindre d'un appareil combinant ampli et dac pour moins de 150 euros ? L'exploit est là, cet appareil fait fonctionner sans problème des enceintes à 88db de rendement avec une dynamique pas ridicule. Et c'est déjà très bien. Mais on est quand même très loin du rendu musical...
The SMSL AD18 V3 is the FDA Full Digital Amplifier par excellence. Providing high-definition melodic sound from both Bluetooth 4.2 and 242kHz USB...
