ELECAUDIO GC-0410 Braided shielding sheath 100% Copper 4-10mm
Shielding sleeve 100% Copper 4-10mm
Reference : 2297
3,10 €tax incl.
2,58 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Gaine vendue au mètre
The braided tinned copper sheath is reputed to protect against Electro Magnetic Interference (EMI).
They are used extensively to reinforce shielded or replacement cables to protection problems arising from data loss or signal interference.
The GCu / Sn braids allow an attenuation of more than 60 dB at high frequencies, from a few kiloherts (kHz) to several gigahertz (gHz).
The braided sleeves offer greater flexibility over film-coated cables.
(Sold by the meter)
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
SHEATH LENGTH DEPENDING ON CABLE DIAMETER (FOR 1M CABLE)
Cable diameterSheath length required
Ø4mm1m
Ø6mm1.08m
Ø8mm1.15m
Ø10mm1.3m
Features:
  • 100% tin plated copper
  • Diameter 4 to 10mm
  • Electrostatic and electromagnetic protection
  • Electrical noise attenuation
  • Improved resistance to abrasion and cuts compared to thermoplastic braided sheaths.
  • Better protection against Radio Frequency Interference (PRE) between 0.5 MHz and 1.7 MHz.
  • EMI / RFI protection
  • Better flexibility
  • Tinned copper wire braid 36AWG
  • Coverage of 85-90% nominal diameter
ColorN/A
ColorChampagne
MaterialCopper
Length (m)Sold by length
Max cable diameter (mm)10.0
7 reviews
efficace
Utilisée sur le câble secteur de mon vinyle et l'alim de mon récepteur Bluetooth . Dans le deux cas la musique est plus incarnée ; une sensation de présence qui implique à l'écoute . Un gain très appréciable pour un coût faible . J'ai déjà remplacé des câbles secteur par des produits de marque onéreux avec des résultats moins concluants . Cependant j'ai essayé le modèle de diamètre supérieur pour les câbles de mes barrettes et j'ai était moins convaincu . Vu le prix à essayé en fonction des résultats .
This review has been posted for ELECAUDIO GC-0410 Braided shielding sheath 100% Copper 4-10mm
Óptimo producto.
Utilizada para realizar algunos cables-filtro con otros materiales de la misma marca y filtros SCHAFFNER, ha sido muy fácil de trabajar. Los cables de alimentación, luego recubiertos por fundas de PET, se quedan flexibles y permiten una cómoda instalación detrás de los aparatos. Muy satisfecho!
Satisfait
Produit conforme, reçu rapidement
Bonne qualité
Conforme. RAS.
parfait .
tres bonne gaine , simple a utiliser car extensible ( ce qui diminue sa longeur , a prendre en compte lors de la commande ) .
je recommande sans réserve.
