ELECAUDIO EB-03 Gaine Tressée Extensible Nylon (PET) 06~12mm
ELECAUDIO EB-03 Gaine Tressée Extensible Nylon (PET) 06-12mm
Braided sheath made of PET (polyethylene terephthalate) monobrins which can be used in a wide variety of applications. Thanks to its expansion properties, PET's unique braiding makes it easy and quick to install on large, irregularly shaped connectors.
Reference : 4915
1,40 €tax incl.
1,17 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Gaine vendue au mètre
Elecaudio EB-03
Braided sleeve nylon PET 6-12mm
elecaudio eb-05 gaine tressée nylon
PET is braided from 0.010" PolyEthylene Terephthalate monofilament for continuous use at temperatures between -40°C and 125°C. Its melting temperature is 210°C. It has good dielectric properties as well as excellent tensile strength and elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computing, scuba diving, electronics, electrical harnesses, audiovisual, and even some military applications.
Electric Blue colour exclusive to the ELECAUDIO brand.
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø6mm1m
Ø8mm1.08m
Ø10mm1.15m
Ø12mm1.3m
Acceptable cable diameter6 to 12mm
ColorElectric blue
MaterialPolyethylene Terephthalate single strand
High elasticity and tensile strength-
Temperatures-40°C to 125°C
Fusion temperature210°C
ConditioningSold by meter
ColorBlue
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)12.0
7 reviews
Parfait!
Une fois pigé la façon de passer la gaine sur le câble, le résultat est top!
Bonne communication avec Audiophonics!
This review has been posted for ELECAUDIO EB-03 Gaine Tressée Extensible Nylon (PET) 06~12mm
Bon produit !
Permet une belle finition des câbles (utilisé de mon côté uniquement sur chaque extrémité de câble côté enceintes et ampli) Deux choses à savoir. Prendre un peu plus que la longueur souhaitée (ça file vite ... ) De plus, si comme moi vous l'associez à de la gaine thermo pour la finition alors coller un petit morceau d'adhésif sur la gaine afin de ne pas la brûler.
En parallèle, je tiens à remercier Audiophonics quant à leur professionnalisme. J'avais en parallèle de cette gaine commandé du câble Mogami 2921 non dispo immédiatement (délai mentionné à côté du produit 7 à 15 jours) mais au bout de 3 semaines ne voyant rien venir, j'ai interrogé leur service cial. La réponse ne s'est pas faite attendre on me proposait soit un câble de diamètre supérieur, toujours en Mogami ou bien le remboursement de ma commande concernant mon câble. Mon système audio étant organisé autour du Mogami 2921 j'ai demandé le remboursement du produit. Le ticket de rembt m'est parvenu quelques minutes après échange avec leur service commercial et dès le lendemain l'argent était transféré sur mon compte. Merci encore à Audiophonics vraiment un site sur lequel on peut commander les yeux fermés c'est si rare aujourd'hui une telle orientation client avec "l'explosion" de tous ces sites se disant vendeurs de matériel (s) audio & hifi. Bravo Messieurs. JB
Buena funda con un color alegre.
El material es excelente y da una buena sensación al tacto. Rápida de utilizar gracias a una buena expansibilidad. Con cable grandes, al limite de sus posibilidades, puede tender a deshacerse: un golpe de mechero en las puntas, antes de empezar la inserción y se soluciona el problema. Utilizada para realizar algunos cables-filtro: acabándola con funda termo retractable el resultado es profesional.
Beautiful
The cable in this braid looks very nice and impressive. Great color and quality
J'ai reçu cette gaine. Je craignais qu'elle soit un peu trop flachi comme sur la photo. Il n'est est rien, le noir domaine avec la touche de bleu.
Ca fait vraiment un très cable qui reste discret tout en apportant une touche qui se détache de l'austérité des cable noir.Je recommande.
Braided sheath made of PET (polyethylene terephthalate) monobrins which can be used in a wide variety of applications. Thanks to its expansion...
