Heat-shrink tubing 2:1 Ø18mm White (1m)
Heat shrink Tubing box 2:1 Ø19mm 1m Blanche
Reference : 9154
2,80 €tax incl.
2,33 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Thermo-retractable sleeve with a 2: 1 ratio, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 2: 1 means that the diameter of the sheath once heated will be divided by 2: for example for a 12mm sheath, after being heated its diameter will be 6mm.
Diameter: 18mm => about 9mm after retraction.
Specifications:
  • Retractable Ratio: 2: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness Retractable: +/- 0.20mm
  • Sheath Thickness After Shrinkage : +/- 0.8mm
  • Temperature Resistance: -55 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 18mm
  • Length: 1m
  • Color: White
ColorWhite
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)18.0
2 reviews
A nouveau satisfait
Mon précédent avis reste valable. Seul maillon de la chaîne à mettre en cause : La Poste ... qui ne délivre pas le colis alors que nous sommes 3 dans la maison ET ne le représente que 5 jours plus tard; bref malgré l'habituelle réactivité d'Audiophonics le colis est arrivé en 10 jours !
This review has been posted for Heat-shrink tubing 2:1 Ø18mm White (1m)
Résultat Impeccable
Se rétracte bien et vite au pistolet à air chaud. Jolie finition pour des câbles d'enceinte. Emballage impeccable et livraison rapide (commande le dimanche; dans ma BàL le mercredi).
