Heat-shrink tubing 3: 1 Ø3.2mm Transparent (1m)
Heatshrink Tube 3: 1 Ø3.2mm 1m Transparent
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
4.0 / 5
Reference : 5621
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Thermo Retractable sheath
Transparent thermo-retractable sheath 3:1 Ø3.2mm (Length 1m)
Gaine thermo rétractable
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Halogen-free, flame retardant, and RoHS-certified.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 12mm sheath, after being heated its diameter will be 4mm.
Diameter: 3.2mm => about 1mm after retraction.
Type of productThermo-retractable sheath
Retractable ratio3:1
Diameter before shrinkingØ25.4mm
Diameter after shrinkingØ8.5mm
Shrink temperature70 - 120°C
Melting temperature of internal adhesive layer70 - 90°C
Sheath thickness front retract+/-0.30mm
Sheath thickness after shrinkage+/-0.95mm
Temperature resistance-45 à +125°c
Dielectric rigidity ≥15 Kv/mm (IEC243)
CertificationsRoHS
Length1m
ColorTransparent
ColorWhite
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)3.2
Gaine conforme mais livrée en morceaux de 1 mètre!!!!
La gaine livrée est tout à fait conforme à ma commande mais j'en avais
commandé 5 mètres et j'ai reçu 5x1mètre!!!!!
This review has been posted for Heat-shrink tubing 3: 1 Ø3.2mm Transparent (1m)
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic,...
