Here is a 5m OFC hybrid cable for HE series HIFIMAN headphones. The latter is intended to replace the basic cables supplied with the Hifiman helmets.
This Hifiman HE400S cable uses silver plated copper multi strands as conductors for better conductivity. Indeed, the OFC (Oxygen Free Copper) technology allows for greater accuracy of signals and performance.
The design of the braided and dielectric cable helps with insulation and protection against external interference. The outer sheath used is flexible and robust both to allow it to carry with it everywhere without damaging it.
The NNew 2.5mm TRS Jack connectors make it easy to insert and remove the cable from the headphones.
Features:/ Strong>
Length (m) | 5.0 |
Section (mm²) | N/A |
Connector | Jack 2.5mm |
Connector | Jack 3.5mm |
Conductors material (Cable) | Copper |
