By buying this product you get 129 loyalty points
14 Days TEST
* This is a test product to allow you to test at home and return within 14 days *
Rediscover High fidelity listening through electrostatic technology.
Try the award-winning KINGSOUND system and discover a high-end listening via our 14 days Test in a few clicks.
7 days Test operation :
1. You add the product to your cart and order.
2. You pay it + postage (as gurantee)
3. You test the product at home for two weeks from receipt.
4. After this period you return the product with the receipt of return provided (no queue at the post office)
5. You will be refunded in full except shipping costs.
In case you want then acquire a product of the KINGSOUND range,shipping fees will be fully refunded.
How does it works ?
The electrostatic loudspeaker is very simple in concept, but difficult to construct successfully in practice.
lts operation relies on electrostatic attraction and repulsion, in much the same way as a piece of thin paper attracted to a rubber balloon that is charged by rubbing it against fabric.
The electrically charged ultra-thin conductive film diaphragm is tensioned and placed close between two metal grids.
When a high voltage audio signal is applied to the metal grids, the diaphragm moves in response to the signal, moving towards the grid which at that instant is oppositely charged, and away from the grid which has the same charge as the diaphragm.
The diaphragm responds in an essentially linear manner, producing sound waves which are a very accurate reproduction of the original sound.
Why is it better ?
Imagine a normal speaker as a point source, from which the sound waves produced diffract at a great angle. This causes rapid decrease in volume and quality over a short distance.
Then imagine a flat electrostatic panel producing sound from the same input signal. This time the sound waves are produced over a large, flat area, therefore have very little diffraction and the volume decreases much less over the same distance.
The electrostatic stereo system is the pinnacle of audio reproduction. The standard upon which all other stereo headphones can be measured.
It literally pushes the limits of the world's most sophisticated instruments that attempt to measure its performance.
The result is an experience that no other stereo system can approach.
The result is an ultra-flat frequency response across the entire range: deep, clean bass with real power that other attempts at electrostatic transducers can only envy.
Le système stéréo électrostatique est le summum de la reproduction audio.
Un système d'écoute professionnel dont la distorsion est infime. Il pousse littéralement les limites des instruments les plus sophistiqués du monde qui tentent de mesurer sa performance.
C'est une expérience que peu de systèmes stéréo peuvent approcher.
Le résultat est une réponse en fréquence ultra-large sur toute la gamme avec un réel pouvoir que d'autres ne peuvent qu'envier.
Caractéristiques techniques du KS-H3 :
Caractéristiques physiques du KS-H3 :
Caractéristiques techniques du M-10 :
Caractéristiques physiques du M-10 :
