Heat-shrink tubing 3:1 Ø19.1mm Transparent (1m)
Heatshrink Tube 3:1 Ø19.1mm 1m Transparent
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Reference : 5625
3,30 €tax incl.
2,75 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Thermo Retractable sheath
Transparent thermo-retractable sheath 3:1 Ø19.1mm (Length 1m)
Gaine thermo rétractable
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 12mm sheath, after being heated its diameter will be 4mm.
Diameter: 19.1mm => about 6.3mm after retraction.
Type of productThermo-retractable sheath
Retractable ratio3:1
Diameter before shrinkingØ19.1.4mm
Diameter after shrinkingØ6.3mm
Shrink temperature70 - 120°C
Melting temperature of internal adhesive layer70 - 90°C
Sheath thickness front retract+/-0.76mm
Sheath thickness after shrinkage+/-2.00mm
Temperature resistance-45 à +125°c
Dielectric rigidity ≥15 Kv/mm (IEC243)
CertificationsRoHS
Length1m
ColorTransparent
ColorTransparent
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)19.1
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic,...
