Heat-shrink tubing 3:1 Ø3.2mm Black (1m)
Gaine Thermo Rétractable 3:1 Ø3.2mm Longueur 1m Noir
Reference : 11927
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 12mm sheath, after being heated its diameter will be 4mm.
Diameter: 3.2 mm => about 1.1mm after retraction
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 3: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness Retractable: +/- 0.50mm
  • Sheath Thickness After Shrinkage: +/- 1.20mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 3.2 mm
  • Length: 1m
  • Color Black
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)3.2
2 reviews
Bien
parfait bonne rétractation
This review has been posted for Heat-shrink tubing 3:1 Ø3.2mm Black (1m)
Shrinks good and does not burn.
Good shrink tube! Shrinks perfectly and does not burn when heated with a lighter. Also does not melt when heated with a solder iron.
