Heat-shrink tubing 4: 1 Ø32.0mm Black (1m)
Heatshrinkable Sleeve 4: 1 Ø32.0mm Length 1m (Black)
3.0 / 5
Reference : 4691
4,00 €tax incl.
3,33 € tax excl.
Shipping from France
Billing in France
Technical support in France
Thermo-retractable sleeve with a ratio of 4: 1, internally equipped with an adhesive layer ensuring better maintenance on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 4: 1 means that the diameter of the sheath once heated will be divided by 4: for example for a 12mm sheath, after being heated its diameter will be 3mm.
Diameter: 32.0mm => about 8.0mm after retraction
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 4: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness After Shrinkage : +/- 2.80mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 32mm
  • Length: 1m
  • Color Black
Length (m)Sold by length
délicate à manier
on est sur du gros calibre!
Attention, il faut beaucoup de chaleur pour la tendre uniformément.
Attention à ce qu'il y a à l'intérieur donc, il faut en tenir compte.
De plus des traces de colle apparaissent aux extrémités sur les gros coèf de retrait.
Pour les experts...
This review has been posted for Heat-shrink tubing 4: 1 Ø32.0mm Black (1m)
