AUDIOPHONICS LPSU25 Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA
AUDIOPHONICS Linear Regulated Low Noise Power Supply USB 5V 3.5A 25VA
4.9 / 5
Reference : 11364
75,00 €tax incl.
62,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Linear Power Supply
Low noise USB 5V 2A 25VA / 220V
audiophonics linear regulated power supply
Audiophile regulated power supply for any Hifi device running on 5V (DAC, digital sources for example).
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
It includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low noise (ripple) of electrical pollution (- of 30mv).
The components of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. A fuse F0.25A 250V ensures the protection of the device.  The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
This regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
As this power supply do not have over current protection, the load should not exceed it's capacity.
For use with a RaspTouch: If a yellow flash appears on the screen, you can adjust the output voltage of the power supply using the screw on the back of the unit until the flash disappears.
AC Power cable sold separately.
Input voltageAC 220V
Output Voltage / current5V 2.0A MAX Continuous
5V 3.5A DC (5 min)
OutputsJack DC 5.5/2.1mm
2x USB-A 5V
InputIEC
Vibration-proof molded transformer 25VA shielded-
Internal fuse0.5A Fast
Case material100% Brushed & Sandblasted Aluminium
AnodisingYes
Dimensions174 x 100 x 51mm
Weight0.85kg
DC 5.5/2.1 jack cord and mains cable not included.
Audiophonics alimentation linéaire régulée
Presentation of the linear power supply regulated by
The Hans Beekhuyzen Channel
We recommend for the ALLO DIGIONE this
Power supply
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)5.0
Output current (A)2.0
Input voltage (V)230.0
Power SupplyLinear
44 reviews
LPSU25
Achetée pour améliorer mon Raspberry DAC PRO 2,
Je suis ravi du résultat obtenu. Graves mieux tenus, reproduction douce et puissante du spectre, possibilité de monter le volume sans distortion si je compare à l'alimentation de base. Un vrai et grand plus pour moi. Merci Audiophonics
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA
Gives a very natural sound
Comparing the Linear Power Supply (LPS) to an IFI Power X powering my streamer:
A bit more subtleties, details and especially more natural. For example different voices are easier to seperate. Emotions in the music are easier conveyed.
Because music sounds apparently less loud, I can turn up the volume higher, yet without getting any listening fatigue.
These small but important improvements brought by this LPS, makes me want to listen, not analytical but for sheer pleasure.
Tutto ok.
Il prodotto si presenta bene, spedizione rapida. Lo sto testando, a breve aggiornerò recensione.
Best performance/price ratio ever
I recently purchased one of these beauties for a customer who is very sensitive to radiation of all sorts and looked for a noise-free replacement for the switching power supply that came with his Squeezebox Classic streamer.
First I went for the ubiquitous Teradak DC-30 but then found out that all sources to buy one are in China. Looked around some more and was amazed to find that there is a French company selling a similar PSU for even less! The ordering process was hassle-free and straightforward. Took less than a week to have it here.
Unfortunately I had only very little time to check it out, but I really like what I see.
I need to emphasize that I don't consider myself an audiophile, I am more focused on things that I can feel and measure. Therefore, I won't share any audition results and comparisons between this PSU and others regarding the sound quality. Sorry folks.
** Case **
The build quality is superb all over. Nice anodized aluminium case, thick front panel, the back panel is also aluminium, everything fits exactly, it's heavy and solid. Chunky IEC power connector, indicator LEDs on the front (white) and back (green). It's a beauty to behold.
** Inside **
Inside things go on like that. Heavy duty toroidal transformer, massively oversized, discrete rectification, four Nichicon electrolytic capacitors, 4700µF/40V each to reduce any ripple, very clean PCB layout. Not a single wire. No flux residue anywhere, it's just as clean as it could ever be.
** Measurements **
There is not much to say about the output. It's absolutely flat 5VDC with no ripple or distortion whatsoever. Even under load this won't change. I hooked up three Squeezebox Classic with a consumption of around 6 to 7 Watts each. Even though this is close to the maximum specified, the PSU had no trouble serving them all the cleanest power. The peak power drawn from the 230V supply was ~34W so it appears that the PSU will consume around 4W for itself per output used. Haven't had the time to play around with smaller loads but I assume this is in relation to the power demands of the consuming device.
Power factor is close to 0.9 which I consider good, not stellar but a lot better than the typical switching power supplies.
Power consumption is shown with 0.0 Watts on the HOPI meter when the PSU is on but nothing is connected! Wow!
The three outputs are joined together but there is so much power available at any time that the consuming devices won't affect each other. This might be different if one emits extreme amounts of distortion, but then such units are best isolated from others and not supplied on the same power rail. Not a fault of this device in any case.
** More Observations **
The unit produces a good amount of warmth so it should not be used in tight spaces with little air around. It's far from red hot though.
There is a fuse inside, protecting the primary side of the transformer. In case it is blown it's just a matter of lifting the top lid and putting in a new one. However, I would have preferred a more accessible place for the fuse, somewhere on the back panel.
The LEDs are just poking through their respective panel, they are not fixed so it's possible to push them in. All that holds them is their own two legs. Not a major concern though, considering the price this is a tiny compromise.
The USB ports don't have a lot of grabbing force. It is rather easy to pull out USB connectors. A bit more spring tension wouldn't hurt.
Although I ordered only a PSU, there was also a 5.5/2.1mm cable delivered along. Nice touch, guys, and very appreciated!
** Summary **
This is an amazing piece of kit, unexpectedly well-built considering the budget price. I think this little thing can compete with PSUs in the price range of 400 to 500 EUR. Much of that goes into the brand names, not the values inside. A lot of attention was paid here, and all pieces that count are well done.
I will recommend this unit, and Audiophonics overall, to anyone who is interested in enhancing their audio equipment and musical experience.
 (4)
Just stunning! Incredible performance for the money
** Case **
** Inside **
** Measurements **
** Summary **
