Ribbon Tweeter BOHLENDER GRAEBENER NEO3W Strong>
The Neo3 is capable of reproducing high frequencies with high accuracy and controlled dispersion. .
Supplied with a rear damping chamber, which can be removed for dipole use.
Themagnetic system is fully shielded for implementation in multimedia areas as well as audio / video systems
The result is a transducer with higher sensitivity and higher maximum output power.
This tweeter can be mounted on 2 types of brackets (flat or curved) for better integration in any enclosure.
the Neo3 has a clean, airy, transparent sound that is intrinsically natural and musically pleasant.
There are no heavy coils, no spiders, no glued joints, no paper cones, no suspension.
There is therefore no deformation due to resonance, no loss of signal or inconsistency which is common in conventional transducers.
The Neo3 has a neodymium magnet push-pull and was designed with the help of Finite Element Analysis software to ensure maximum efficiency
Specifications: Strong>
