FOUNTEK NEO X3.0 Speaker Driver Ribbon Tweeter 30W 8 Ohm 95dB 1200Hz - 40kHz Silver
FOUNTEK Neo X3.0 Silver Tweeter à ruban
Reference : 8924
155,00 €tax incl.
129,17 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
The Fountek Neo X3.0 ribbon tweeter has the advantages of this technology:
  • Flat frequency response
  • High Quality Harmonics
  • Transition, impulse response faster than a conventional tweeter
  • Low resonance
  • Yield of 95dB
The Fountek ribbon tweeters are equipped with a low induction impedance transformer allowing the ribbon to adapt perfectly to the amplifiers on the market.
Here is an excellent choice competing with the best dome tweeters from the market for a lower price.
Features:/ Strong>
  • Sensitivity: 95 dB / 1m / 2.83 V
  • Power: 30W nominal, 50 W max
  • Frequencies: 1,200-40,000Hz
  • Impedance: 8 ohm
  • DCR: 0.02 ohm
  • Dimensions: 12mm x 80mm x 0.015mm
  • Effective ribbon zone: 960 m²
  • Ribbon Weight: 36 mg
  • Height Gap: 13 mm
  • Recommended cut-off frequency: 2,000Hz with 2 orders
  • Net weight: 1,015 g
https://www.audiophonics.fr/images2/8722/8722_fountek_Neo_X3.jpg
https://www.audiophonics.fr/images2/8722/8722_fountek_Neo_X3_4.jpg
Speaker Power (W RMS)30
Speaker TypeRibbon tweeter
Impedance (Ω)8
Loudspeaker diameter (mm)N/A
Diaphragm typeN/A
Efficiency / Sensitivity (dB)95.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)1200
Highest frequency (Hz)40000
