ELECAUDIO FC105T Multistrand wiring cable Copper FEP 0.5mm² Red
ELECAUDIO FC105T Fil de Câblage Cuivre FEP 0.5 mm² (Rouge)
4.8 / 5
Reference : 4657
2,20 €tax incl.
1,83 € tax excl.
Shipping date: 28-03-2024.
Shipping from France
Billing in France
Technical support in France
This single-conductor cable is particularly suitable for internal wiring of devices. Thanks to its FEP-type dielectric insulation, it will be beneficial in any installation requiring high quality, time-resistant wiring at higher temperatures, especially for Class A amplifiers.
Its 0.5mm² core structure made of fine-stranded OFC copper (45 strands of 0.12mm) makes it a good price-priced choice with a wide choice of colors available in black , red or white for easy assembly.
Its stability over time and its electromechanical qualities make it a cabling element for countless assemblies.
It can be used for making the following cables:
  • Multi-stranded speaker cables
  • Analog Modulation Cables
  • Internal wiring of High Fidelity devices
  • Wiring for tweeters
Specifications:
    • OFC Copper
    • Insulating sleeve in (FEP)
    • Heat resistance: 200 °
    • Conductor Section: 0.5mm²
    • Cable structure : 45 strands of 0.12mm
    • Outside Diameter of the Cable: 1.50mm
https://www.audiophonics.fr/images2/4657_ELECAUDIO-FC105-TS-RED_1.jpg
https://www.audiophonics.fr/images2/4657/4657_ELECAUDIO.jpg
Diameter (mm)1.5
Length (m)Sold by length
Number of conductors1
Insulation materialFEP
ShieldingNo
Section (mm²)0.50
Ground / ShieldingNo
4 reviews
très bien
Câble semi rigide argenté de qualité. La gaine se dénude facilement et ne brûle pas durant le soudage. Capillarité parfaite pour la soudure. A découvrir pour le câblage d'un appareil audio de haut niveau.
This review has been posted for ELECAUDIO FC105T Multistrand wiring cable Copper FEP 0.5mm² Red
Fil de câblage 0,5mm2
Retour d'expérience,
Ce câble de bonne qualité se travaille bien, de plus l'isolant résiste à la chaleur du fer à souder
Produit recommandé
Fil de Câblage Cuivre FEP 0.5mm² (Rouge)
Très bien pour le câblage interne
câble multibrins
câble de qualité avec un bon isolant
Utilisé en interne pour préamp
