NEOTECH SOST-24 wiring cable UP-OCC PTFE 24AWG
Reference : 10650
31,90 €tax incl.
26,58 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
NEOTECH SOST-24
Neotech's leading high-tech hi-fi cable icts continuous investigation in the field of sound reproduction and today Produces the ultimate in cable modulation, digital SPDIF, AES EBU, speaker and high- End.
The single-crystal SOST Solid Core Silver Wire cable series Allows the Highest Quality Silver OCC UP cables to be Produced with high-grade PTFE Teflon dielectric insulation.
You can now design pure silver cables and access the references of the High End Audiophile cable market. The method of Professor Ohno of the Chiba Institute of Technology of Japan Makes It can to raise the purity of the 99.99998% pure copper and silver strands above-the level of the standard annealed OFC cables.
The oxygen particles inside the silver strands are THUS Reduced to an insignificant level Ensuring a high level of stability over time qui Prevents oxidation over the long term.
The Neotech SOST UP OCC Silver exists in different diameters Corresponding to all the expectations for the Informed amateur Building His Own Stereo cables.
InsulationPTFE (Teflon).
ConductorUP-OCC Silver Solid Core (Pure silver to 99.99998%)
Internal diameter0.5 mm
Outside Diameter1.2mm
AWG24 /0.20mm²
High intensity5.4 ampere
colorBlue
Sold by the meterBy the meter
Diameter (mm)1.2
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.2
Conductors material (Cable)Silver
Ground / ShieldingNo
DC-Kabel für High End Low Noise Netzteil
Ich habe das Kabel eng verdrillt mit passendem Sleeve mit einem Oyaide Stecker konfektioniert und verwende es als DC-Kabel für mein Hoerwege-Netzteil am Auralic Aries Femto. Mit dem Kabel klingt meine Kette noch etwas feinauflösender, luftiger und vielleicht einen Tick schneller. Es zischelt nicht und produziert keine Schärfe.
This review has been posted for NEOTECH SOST-24 wiring cable UP-OCC PTFE 24AWG
