NEOTECH SOST-26 Wiring Cable Single Stranded UP-OCC PTFE 0.128 mm²
NEOTECH SOST-26 wiring cable UP-OCC PTFE 26AWG
The SOST Solid Core Silver Wire single-crystal cable series makes it possible to manufacture UP OCC Silver cables of the highest possible quality, with high-performance Teflon PTFE dielectric insulation.
Reference : 10651
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
NEOTECH SOST-26 Fil de câblage UP-OCC
Neotech, leader in high-tech HiFi cables, continues its investigation into the field of sound reproduction, and today produces the ultimate in its own design of modulation, digital SPDIF, AES EBU, speaker and high-end power cables.
The SOST Solid Core Silver Wire single-crystal cable series makes it possible to manufacture UP OCC Silver cables of the highest possible quality, with high-performance Teflon PTFE dielectric insulation. Now you can design pure silver cables at home and reach the level of the High End references in the audiophile cable market.
The process developed by Professor Ohno of the Chiba Institute of Technology of Japan raises the purity of the copper and pure silver strands to 99.99998% above the level of standard annealed OFC cables. Oxygen particles inside the silver strands are thus reduced to an insignificant level, ensuring a high level of stability over time and preventing oxidation over the long term.
The Neotech SOST UP OCC Silver solder cable series is available in a range of diameters to suit the needs of the discerning amateur building his own Hifi cables.
Tableau comparatif cuivre OCC vs Cuivre OFC
Technical characteristics:
  • Insulation : PTFE (teflon).
  • Conductor: UP-OCC Silver solid core (99.99998% pure silver)
  • Internal diameter: 0.38 mm
  • Outside diameter : 0.98 mm
  • AWG : 26 /0.128mm²
  • 3.9 ampere
  • Color: blue
  • Sold by the meter
https://www.audiophonics.fr/img/p/7/4/4/0/7440.jpg
Diameter (mm)1.0
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.128
Conductors material (Cable)Silver
Ground / ShieldingNo
Superbe produit
Le départ, à réception, sa gaine diélectrique PTFE bleue est magnifique, bien mieux en vrai qu'en photo, d'une régularité polie sans faille !!! Le conducteur en argent monobrin, sésame de ce fil de câblage, est très souple.
Une mise en oeuvre soignée permettra d'approcher le meilleur du câble / câblage interne.
Par contre, bénéficiant d'un pied à coulisse numérique, je me permets de rectifier certains paramètres erronés, énoncés dans le descriptif-produit:
Diamètre interne : 0.40 mm (au lieu de 0.52 mm)
Diamètre extérieur : 1.12 mm (au lieu de 1.7 mm, donc passera dans de plus petites gaines coton tricotées)
AWG : 26 /0.128mm² : c'est bien ça, 100% conforme
J'ai hâte de l'entendre en configuration balanced (soudées aux XLR Neutrik plaquées silver)
Cordialement
 (5)
This review has been posted for NEOTECH SOST-26 Wiring Cable Single Stranded UP-OCC PTFE 0.128 mm²
The SOST Solid Core Silver Wire single-crystal cable series makes it possible to manufacture UP OCC Silver cables of the highest possible quality,...
