FURUTECH FI-INLET IEC Plated 24k Gold Plated
FURUTECH FI-INLET IEC Gold plated 24k
The contacts of this Furutech IEC receptacle benefit from the brand's α (Alpha) treatment. This consists of a two-step process to maximise conductor performance.
4.9 / 5
Reference : 2170
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
INLET IEC FURUTECH
FI-INLET RHODIUM Plated
Furutech e-TP60E NCF Distributeur Secteur 6 Prises Plaqué Or
α (Alpha) treatment
The contacts of this Furutech IEC socket benefit from the brand's α (Alpha) treatment. This consists of a two-step process, aimed at maximizing driver performance. The first step, cryogenics, brings the conductive material to a temperature between -196°C and -250°C. The treated elements then change their molecular structure, improving the electrical conductivity of the material. The second phase consists of exposing these same elements to a very effective demagnetization process, totally eliminating the magnetization of the material.
Product typeINLET IEC
Conductor materialCopper Alloy with anti-magnetic"Furutech Alpha α" treatment
Conductor platingGold 24k
Body materialPBT and fiberglass housing
Type de montage4.8mm terminals or to weld
Nominal tension 15A/125V - 10A/250V
Dimensions (LxDxH)49.5 x 22 x 18.5 mm
Drilling spacing40mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Rated current (A)10.0
Rated current (A)15.0
7 reviews
Prise de qualité
À acheter les yeux fermés si vous voulez être sûr que la prise ne fonde pas avec un excès de chaleur lors du soudage des connecteurs.
This review has been posted for FURUTECH FI-INLET IEC Plated 24k Gold Plated
Excellente embase
Très bonne embase. Bonne résistance mécanique. Excellente résistance au soudage. Connecteur arrière bien dimensionné pour une multitude d'option de soudage. Donc excellent rapport qualité/prix.
Très bien
Très bonne prise.Cela m'a permis de mettre un bon câble secteur et la qualité sonore s'en trouve bonifiée pour un prix correct
Parfait
La qualité de maintien du contact parfaite pour le prix d'une prise de qualité.
Brassage facile.
efficace
en remplacement d'un cordon secteur prisonnier...fait le job!
The contacts of this Furutech IEC receptacle benefit from the brand's α (Alpha) treatment. This consists of a two-step process to...
