FX-AUDIO FX252A Class D TDA7492E Amplifier 2x68W 4 Ohms Black
4.8 / 5
Reference : 12149
34,90 €tax incl.
29,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
FX-AUDIO FX252A
- Amplifier Class D TDA7492 2x68W -
FX-Audio FX252A
FX-Audio offers with its FX252A a Class D amplifier capable of delivering up to 2x68W under 4 Ohms in a very reduced format.
ST ELECTRONICS TDA7498E
The FX252A incorporates a ST Electronics TDA7498E amplification chip. This delivers 2x68W 4 Ohms power and takes advantage of the high efficiency of a Class D amplifier to bring the power needed to your speakers. It incorporates a noise reduction system and protections against short circuits and excessive temperatures. In addition, it allows to simply select the fixed gain via the DIP switches under the device to the following values: 20.8dB, 26.8dB, 30dB and 32.8dB.
Componentss of quality
The amplifier benefits from a design and components of qualities. A series of capacitors reduce residual noise and distortion, and a YXG Rubicon capacitor ensures stable, clean power. The connectors benefit from gold plating to ensure good conductivity and durability.
A sober but elegant design
Featuring a brushed aluminum black body, this FX-Audio FX252A boasts a sleek yet stylish design that will fit into your audio system.
TECHNICAL CHARACTERISTICS
  • Amplifier Chip: ST Electronics TDA7492E
  • Input: RCA Stereo
  • Output: 2-channel speaker terminals
  • Connector Plating: Gold
  • Yield:> 85%
  • Supported Speakers: 4 - 16 Ohms
  • Power Supply: DC 15V 4A (included) / DC Jack 5.5 / 2.1mm ((Possibility to upgrade to a 24V 5A power supply)
  • Housing material: CNC machined aluminum
  • Black color
  • Weight: 340g
  • Dimensions: 98 x 123 x 33mm
FX-Audio Amplifier FX252A
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA7492E
Power (W)68.0
13 reviews
Surprenant petit engin!
Acheté pour remplacer un Luxman l-225 (qui part au récapage) Je souhaitais monter un système de bureau pour le brancher sur mon pc. Un système correct, moins encombrant et plus raisonnable en matière de consommation énergétique.
je regardais,lisais les différents avis et commentaires ici et sur plusieurs forums. Ces amplis classe D m'intriguaient, J'ai franchi le pas.
Cet appareil est excellent, je n'en rajouterai pas, tout est dit dans les commentaires sur la capacité de cet ampli à faire de la musique!
Testé via une carte son externe Soundblaster SBX avec les lecteurs WMP et MusicBee uniquement des fichiers wave sans perte, sur des enceintes Mission 700 de la fin des 90's et sur des Focal 706s via câbles d'enceintes Sommercable Orbit 2.5, USB SUPRA et modulation DIY Sommercable Onyx/RCA Neutrik dans une pièce de 12m2)
J'écoute (presque) de tout: jazz, metal, grind, rock, rock-prog,pop , électro etc...du bien violent au plus doux.
Avec les mission,j'étais déjà surpris, mais avec les Focal!!! là c'est énorme!
J'avais lu que ces amplis n'avaient pas la capacité d'étreindre l'auditeur comme le fait un ampli classique, avec les focal, ce n'est plus vrai.
Le son est vivant, immersif, précis. C'est un peu "froid" sur des voies jazz, mais je pense que cela doit pouvoir se résoudre pour pas cher avec les petits buffer à lampes que l'on trouve sur ce site notamment.
C'est l'avenir.
ps: contrairement à ce qui est précisé,cet appareil m'a était livré avec une alim 24v 4A
This review has been posted for FX-AUDIO FX252A Class D TDA7492E Amplifier 2x68W 4 Ohms Black
bien
22.06.2019
Bonjour à tous
Je possédais déjà le petit pré-ampli à Tubes le FX-AUDIO TUBE-03 que j'ai associé à petit ampli FX-AUDIO FX252A amplificateur Class D pour brancher au PC avec un petit FX-AUDIO FX01 DAC USB comme je suis néophyte je croyais que je pouvais brancher ms haut-parleurs JAMO directement sur le DAC USB. Après avoir pris contact par E-Mail avec Monsieur David AUBERT, j'ai branché Mon DAC USB avec l'ampli et le pré-ampli a Tubes. Pour moi avec ces 3 petits appareils le son est plus claire que mon système son 2.1 de mon pc je ne regrette pas mon achat, car pour le prix j'ai l'impression d'avoir un meilleur son.
Ps: j'ai quand même changé les Tubes pour VOSKHOD années 1970
Monsieur RICHARD
mode d'emploi absent mais écoute superbe
Livraison et mise en œuvre 4 étoiles
Bonjour ami mélomane, merci pour vos avis, à mon tour
Livraison dans les délais et mise en route simple, appareil bien enveloppé : bon boulot du personnel d'Audiophonics.
Informations, optimisation : 1 étoile
Pas évident sur le site de poser des questions pour des conseils pour choisir le matos. Interface du site qui donne pas envie de demander. Je suis un amateur un peu éclairé mais pas un professionnel.
Je voulais commander une autre alimentation. Mais je n'ai pas compris comment substituer et à quel prix , celle plus puissante suggérée à celle d'origine.
Mise en route du fx252A : un gros point noir pour l'absence de mode d'emploi pour le "gain setting" situé sous l'appareil. Une feuille photocopiée m'aurait suffi. Donc j'ai un appareil que je ne peux pas optimiser et me priver peut-être de ces capacités . Je ne vais pas bidouiller à l'aveugle au risque d'abimer mon système. Le tournevis oui, le BTS en électronique non.
Le boitier est bien fini avec des connecteurs bananes sérieux et un interrupteur vintage de bon aloi avec une diode bleue assez discrète. Rien à redire vu le prix.
Ecoute 5 étoiles
Le système : windows 7, lecteur foobar, driver asio, fichiers flac (450k à 700k) ou mp3 (192k & 320k) , DAC FX 01 (mise en route simplissime et très très musical pour son prix) sur la sortie USB2 ; CD linn Karik le tout relié au pré-ampli kairn connecté au FX252A .
Enceintes ninka 4 ohms en passif ( 90db 1w/m à1khz) câbles linn : modulation et enceintes.
L'écoute du fx252A : plusieurs heures avec du classique , de la pop, de la world musique , des chœurs etc...(fichiers via DAC et CD)
Impressionnant rapport qualité prix le FX252A rend justice au Kairn avec autorité (j'avais un LK140 en ampli qui a pris la foudre) . Pour ce tarif et la puissance annoncée le FX252A est un bonheur fait musique.
Respect des timbres et des voix sans coloration, stabilité de l'image, suivi rythmique, tenue des enceintes, étagement des plans sonores et des registres : tout est impeccable. Chaque enregistrement est différent et respecté sans projection ni fatigue auditive. Que du meilleur pour ce prix.
Hormis les réserves exprimées plus haut sur le mode d'emploi absent. Cet ampli joue superbement bien de la musique et à ce tarif il est possible, à mon avis, de monter un système qui fait de la musique pour la moitié du prix d'un smartphone jetable au bout de 2 ans.
Vivement un mode d'emploi ou des explications claires et des euros dans ma cassette pour un autre FX252A et passer en bi-amplification .
Mérite très largement 5 étoiles mais le réglage obscur du "gain setting" sur un ampli de puissance (un comble !) m'oblige à retirer une étoile .
IRREPROCHABLE
Pour un prix dérisoire un son incroyable naturel et équilibré , du détail , les basses descendent très bas., Fonctionne avec l'alimentation 5 ampéres conseillez par audiophonics ( je n'ai pas testé l' alimentation d' origine) . Associé à des bc acoustiques niger fait aussi bien que mon ancien ampli bc acostique à 350 euros. Attention toutefois prévoir des fiches bananes ( bornier très petit ). Bravo FX audio.
Very good amplifier ..
The amplifier was installed in a large room ..
I am very satisfied with the small part .....
Thanks to the Audiophonics team
