IEAST STREAMAMP AM160 Wireless Multiroom Stereo Amplifier TDA7498 2x40W 8 Ohm Black
iEast StreamAmp AM160 Wireless MultiRoom stereo Amplifier 2x65W / 8 Ohm Black
The iEast StreamAmp AM160 is a small amplifier with the particularity to integrate a complete network connectivity, allowing you to simply stream your music remotely from a device connected to the same network (smartphone, computer, NAS...) or from a compatible streaming service.
2.0 / 5
By buying this product you get 26 loyalty points
Reference : 11593
269,00 €tax incl.
224,17 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
StreamAmp AM160
StreamAmp AM160 Amplificateur sans-fil multiroom TDA7498 2x40W 8 Ohm Noir StreamAmp AM160 Amplificateur sans-fil multiroom TDA7498 2x40W 8 Ohm Noir
The iEast StreamAmp AM160 is a small amplifier with the particularity to integrate a complete network connectivity, allowing you to simply stream your music remotely from a device connected to the same network (smartphone, computer, NAS...) or from a compatible streaming service. The amplifier can also work in a multi-room environment, allowing you to sound several rooms in your home and control their playback via a dedicated application.
TDA7498 Amplifier
The Class D amplifier stage of the StreamAmp AM160 is based on a TDA7498 chip, capable of delivering 2x40W at 8Ω or 2x80W at 8Ω. Comfortable power combined with high efficiency and a transparent and precise reproduction. This amplifier chip is associated with a digital DSP.
WM8918 DAC
The digital/analog conversion stage is entrusted to a WM8918 DAC chip, supporting PCM sample rates up to 24bit 192kHz. This chip allows a high quality conversion, greatly contributing to the AM160's quality of reproduction.
Connectivity
The iEast Streamamp AM160 is a network amplifier, making it easy to stream music over the network. Thus, it integrates an Ethernet RJ45 connection as well as WiFi reception. It is compatible with DLNA, AirPlay or Spotify Connect protocols as well as many streaming services. Control is simply done via a dedicated application available on Android and iOS.
The amplifier also has a USB-A 2.0 port for connecting a storage device (USB stick, hard disk) and an RCA input for connecting another source.
Streaming
The StreamAmp AM160 is compatible with many streaming services, allowing you to easily stream your music from any of them: Spotify, Qobuz, Deezer, Tidal, Tune In...
iEast Play App
Control is simple and intuitive from the dedicated iEast Play application, available free of charge for Android and iOS devices.
Qobuzissime for the iEast StreamAmp AM160
" In conclusion, rewarding a Qobuz switching amplifier is becoming a common occurrence at Qobuz, and we are all the more pleased to award it to this iEAST AM160 model as it integrates our Hi-Res application and allows you to enjoy it to the fullest. "
Qobuzissime pour le iEast StreamAmp AM160
Product typeAmplifier
Amplification chipTDA7498
DAC chipWM8918
Power2x40W @ 8Ω, 32V, THD 0.15%
2x30W @ 8Ω, 32V THD 0.06%
2x80W @ 4Ω, 32V, THD 0.6%
2x40W @ 4Ω, 32V, THD 0.2%
2x50W @ 6Ω, 32V, THD 0.3%
2x30W @ 6Ω, 32V, THD 0.16%
Inputs1x USB-A 2.0 (For USB mass storage)
1x RJ45 (TCP/IP LAN 10/100Mbps)
1x Stereo RCA
WiFi 802.11 b/g/n 2.4GHz (WPA / WPA2)
OutputSpeaker terminals
Streaming servicesSpotify, Qobuz, Deezer, Tidal, Tune In, iHeartRadio, Pandora, Napster, radios internet,QQ Music...
Network protocolsDLNA
UpNP
Spotify Connect
AirPlay
QPlay
WPS compatibility
SNRNet / USB : > 80dB
Aux input : > 90dB
Supported sampling rate24bit 192kHz
Supported file formatsMP3, AAC, AAC+, ALAC, FLAC, APE, WAV
Dimensions200 x 116 x 30mm
Weight680g
Package1x iEast StreamAmp AM160
1x Power adapter 32V 5A
1x RCA Cable
1x Antenna 3dB
4x Banana connectors
Firmware 4.2.7709.27Deezer support
Amazon Music support (only US)
Direct streaming from the application
Adjustment of bass and treble from app
Adding presets
Optimization of stability and reliability
InputWiFi
InputRJ45
Mise en service laborieuse, puissance pas à la hauteur des promesses.
Échec d'une mise en service sous Wifi Laborieuse avec bouclage sur une incompréhensible demande de se connecter au réseau wifi local, puis échec car redemande de se reconnecter au réseau SETUP puis rebouclage, bref aucun résultat ni à partir de la Tablette ni du Smartphone, abandon du wifi pour l’Ethernet, où enfin l'appareil est reconnu comme appareil Airplay et DLNA.
Documentation indigente et inutile, ne présentant que les étapes devant se dérouler normalement, en cas d'échec aucune piste ni aide.
A l'écoute (colonnes CABASSES 3 voies 2X100W) son correct, mais les 2x65 watts RMS semblent ridicules à l'écoute par rapport à mon vieux SANSUI au-217 de 2x25 Watts RMS seulement, en terme de dynamique et réserve de puissance !!!!. Bon cela conviendra pour l'usage d'un système d'écoute accessoire dans la chambre à coucher, le lieu d'écoute principal reste étant équipé de 2x 1500 Watts RMS avec une qualité d'écoute magnifique. Pourquoi ne pas avoir rajouté deux sorties RCA pour attaquer un ampli de puissance dédié par exemple à un caisson de basses ou autre amplification sur deux enceintes supplémentaires ?.
Donc au final cher pour les services rendus.
Bonne journée.
Bonjour,
Cette technologie (linkplay) est commune à la plupart des produits DLNA / UPNP présents sur le marché (toutes marque et modèles confondus).
Nous sommes navrés que vous ayez rencontré des difficultés à le configurer (c'est assez inhabituel).
Concernant la puissance, j'avoue être perplexe et ne pas comprendre comment un Class D ne donne pas plus de puissance et de dynamique qu'un Class A/B vintage.
This review has been posted for IEAST STREAMAMP AM160 Wireless Multiroom Stereo Amplifier TDA7498 2x40W 8 Ohm Black
The iEast StreamAmp AM160 is a small amplifier with the particularity to integrate a complete network connectivity, allowing you to simply stream...
