QULOOS QA690 FDA Power Amplifier 24bit 192khz XMOS 2x100W / 8 Ohm
QULOOS QA690 FDA Power Amplifier 32bit 384khz XMOS 2x100W / 8 Ohm
The QULOOS QA690 Full Digital Amplifier FDA is a worthy successor to the QLS QA-100, the first affordable high quality FDA amplifier on the market.
4.8 / 5
By buying this product you get 81 loyalty points
Reference : 11366
819,00 €tax incl.
682,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Quloos QA680
Truly innovative FDA technology:
The Full Digital Amplifier FDA QULOOS QA690 is the worthy successor of the QLS QA-100, the first affordable FDA amplifier on the market that is unanimously acclaimed by its users.
the QULOOS QA690 takes back the electronic quality, the very high level components of the QA100 by bringing innovations which were lacking. Thus, the Quloos brand designer listening to his customers now offers much more than a revision of the QA-100.
The QULOOS QA690 offers all the advantages of FDA amplification with an audio signal reducing all stages of conventional conversion and amplification by only 3 stages instead of the usual 8.
FDA amplifiers, which can be described as digital power converters, offer today a real evolution and alternative to traditional analog and digital amplifiers.
amplificateur FDA Quloos QA680
Very high level active and passive components:
Based around two 150W TAS5624 amplification chips (Texas Instrument), the QA690 offers the ultimate in Full Digital Amplifier.
The asynchronous signal reshaping input chip SRC AKM AK 4137 sends the PCM or DSD audio stream into the amplifier chips with as little jitter as possible.
Inspired by the Quloos QA661 Digital player, the two clocks of the QA690 have their own separate power supplies on LT1763 regulator and ceramic VIMA and NPO film capacitors (thermal stability).
The separate XMOS USB input card features the latest technology from High-End Hi-Fi.
The phase noises (jitter) are thus rejected at the limit of the measurable bringing a liquid, full, analog sound. The design and manufacturing quality of the QA690 far exceeds the usual criteria that have earned the brand its reputation.
The best passive components are in the QA 690 : VIMA, Panasonic capacitors, Vishay MELF and Holco resistors, shielded filter coils at the output.
An analog filter and a high level PSRR power supply:
The power supply with British brand Kemet BHC capacitors (2x10000 µf) is now shielded and separated from the rest of the electronics greatly reducing EMI and RFI pollution between components.
With a significant number of separate LDO low noise controllers (LT1965, LT1963, LM1086) for each voltage, the QA690 offers a stable electrical voltage quality with a high noise rejection rate, necessary for optimal digital signal rendering.
The QULOOS QA680 chassis is made entirely of military grade aluminium on CNC Pirelli machines.
Quloos QA680
Quloos QA690 review bt Qobuz
" This powerful all-digital amplifier, designed with great seriousness and offering a sound reproduction with a more or less modular clarity according to its tastes, is a choice element to constitute the heart of a quality hi-fi system in a traditional format adapted to the restitution of dematerialized music. "
Test Qobuz
The On/Off button on the front panel is not backlit.
Characteristics:
  • Integrated amplifier FDA 2 amplifier chips TAS5624 2X100 W on 8Ohm
  • High Definition 24bit 192Khz XMOS USB input
  • PurePath Digital Texas Instrument Technology
  • High and low settings
Inputs and outputs:
  • One Asynchronous XMOS USB input: 24 bit 44.1~192Khz and DSD
  • Two 192Khz 24bit SPDIF coaxial inputs
  • One Toslink 24bit 192Khz optical SPDIF input
  • One analog line input on Cinch RCA stereo
  • One stereo speaker output on gold-plated screw terminals
Technical data:
  • Power under 8 Ohm : 2x 100W
  • Power under 4 ohm : 2x160W
  • Dynamic capacity: 101dB
  • Signal-to-noise ratio : 101dB
  • Channel separation: 97dB
  • Distortion : 0.02%
  • Frequency Response: 10 to 20Khz
  • Power consumption in standby mode: 13w
  • Signal ratio, Speaker output: 117dB
Dimensions :
  • 300x216mm x100mm (excluding RCA and volume knob)
  • Weight: 5Kg
Bundle :
  • Remote control with volume control
  • 1m50 USB 3.0 cable
  • 1m50 SPDIF µ-OFC coaxial cable with EMI ferrite
  • IEC mains cable 3 poles
  • Instructions for use in English
Quloos QA680
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTAS5624
Power (W)100.0
13 reviews
Exceptionnel
Je n'ai pas l'habitude d'écrire un avis suite à mes achats, mais là je fais exception à la règle. Je fais tourner cet ampli avec des atlantis lab AT31 : une claque monumentale, je ne décolle plus de mon canapé. J'ai également un ensemble jolida à près de 9k€, un isem elixis millenium à 2k€. A mon sens et après comparaison sur ces enceintes, il est au dessus tout ça : une écoute ultra détaillée jamais agressive, des basses profondes qui me manquaient avec l'elixis, une écoute cristalline à souhait qui me manquait avec le jolida et une superbe ouverture sans perdre en crédibilité.
Si j'avais su j'aurais économisé 10k€ et je me serais limité à cette petite boite dont la taille est inversement proportionnelle aux performances qu'elle délivre.
J'aime les écoutes analytiques tout en restant réalistes et là je suis comblé.
Les produits chinois n'ont vraiment plus à rougir de leurs concurrents du vieux continent ou d'outre atlantique, c'est une évidence pour moi. Et niveau fiabilité c'est également un constat que 'on peut faire aujourd'hui à mon avis.
Cet avis que je dépose ici n'engage que moi, donc pas la peine de me dire que je ne sais pas de quoi je parle. Je suis extrêmement exigeant au niveau du son, qu'on se le dise.
 (3)
This review has been posted for QULOOS QA690 FDA Power Amplifier 24bit 192khz XMOS 2x100W / 8 Ohm
What an amp!!
I have bought this amplifier after a long and extremely informative exchange with David from Audiophonics. He recommended me this amp as an ideal match for my power hungry KEF LS50. He was so right!! The amp has so much authority over the KEF's, running them with ease. The sound is amazing, detailed, clear and far away from being harsh in any way. It also has a certain warm and deepness to it, you wouldn't immediately expect from a Class D amp. The Quloos has a lot to offer, he would easily compete with far more expensive amplifiers with his specs. The build quality is very solid and for years to last. I love this thing already and I want to say thank you to David and the Audiophonics team for their advice and their patience during my decision making. This amp is an insider tip, for sure!!!
Apres un an toujours plus jouissif , mais...
Après un an d'écoute, je remets mon grain de sel.
La qualité du Quloos m'a amené à changer : mon steamer, mes enceintes et mes câbles.
Comme le souligne Jean-François C. une mauvaise association peut lui être fatal. Dans mon cas, le changement d'un câble audio USB a rendu les aigus agressifs. C'est seulement avec l'arrivée d'un nouveau steamer (ALLO USBridge Signature) que j'ai pu utiliser le câble.
Donc vigilance, car l'incroyable précision du Quloos peut être aussi son pire ennemie.
Mais avec de bonne associations, je n'ai pas trouvé une tel qualité sonore (j'aime l'ultra précision) dans d'autre système (ampli+dac) qui coute jusqu’à 10 fois plus chère.
DES QUALITES ... ET ES DEFAUTS.
Lors des premières écoutes de cet ampli on ne peut qu'être enthousiasmé par la transparence absolue de la restitution, mais c'est seulement sur la durée qu'on peut vraiment juger un appareil, c'est d'ailleurs pour cette dernière raison qu'un achat est si hasardeux; j'en parle en connaissance de cause et pourvu d'une longue expérience. Il faut donc avouer que cet amplificateur ne s'adapte pas à tous les types d'enceintes comme nous le verrons par la suite. Posons d'abord le doigt sur les qualités de ce Quloos QA690. Sa très grande transparence vous révèlera l'intégralité du message encodé, mais c'est sur sa capacité à restituer les nuances les plus fines que cet appareil impressionne. Les instrumentistes et les chanteurs ne jouent pas tantôt forte tantôt piano mais dans une gradation quasi infinie entre les nuances extrêmes et je dois avouer qu'aucun des nombreux amplis que j'ai possédés ne parviennent à un tel résultat. Passons aux revers de la médaille maintenant. Cet appareil a une tendance à "dégraisser" excessivement les timbres ce qui les déleste de leur corps, de leur matière, si toutefois on peut parler de matière pour des notes! enfin vous saisissez sans doute ce que je veux dire. En conséquence le piano apparait maigrelet, et finalement irréaliste, en particulier dans le bas du spectre et les réglages de tonalité disponibles n'y apportent aucune réelle amélioration. L'autre extrémité du spectre est également sujette à critique: les violons jouant dans l'aigu ne sont pas dépourvus d'une certaine acidité voire d'agressivité. On aurait souhaité un léger lissage qui donnerait aux cordes une belle texture. La transparence sans concession de cet appareil le dessert sur ce point en révélant absolument tous les défauts des prises de son tout autant que ceux des instrumentistes ou chanteurs. Associé à des enceintes douces qui tendent à atténuer le haut du spectre (type Elipson prestige) les résultats globaux sont bons mais associé à des enceintes très transparentes et analytiques (type highland Audio, Monitor Audio...) ce Quloos QA690 risque de décevoir le mélomane exigeant recherchant les sensations de la salle de concert. Un appareil à associer donc avec des enceintes ayant du corps et possédant un équilibre descendant.
Très très bon... donc très content ! :)
J'ai acheté cet ampli-dac sur ce site début Septembre 2019, j'ai donc 8 mois de recul pour donner mon avis.
Il alimente des Magnepan 1.7 (rendement de 86 db et impédance de 4 ohms) dans un salon de 14m2, les doigts dans l'nez !
Je suis toujours autant sidéré de la facilité qu'il a à les faire chanter sur n'importe quel type de musique et l'association des 2 marques me donne le plus de plaisir sur la musique classique, le jazz ancien ou moderne... avec énergie, avec douceur, avec finesse et tout le temps avec musicalité.
Même sur les films (en 2.0), je ne me pose aucune questions tellement il colle aux effets sonores avec justesse, le réalisme est bien là.
Bref, soyons très clair, le rapport qualité prix est vraiment de haut niveau : aucune frustration, aucun regret... que du plaisir ! :)
Une petite question technique, par simple curiosité, à l'adresse d'Audiophonics : sauriez vous me dire la puissance de l'alimentation (500VA... ?) et la valeur du facteur d'amortissement du Quloos QA690, s'il vous plait ? Merci d'avance. :)
 (3)
