Rythmik Audio DS1501 SLV 15 "+ Amplifier A370PEQ3 DIY KIT
Rythmik Audio DS1501 SLV 15" + Amplifier A370PEQ3 DIY KIT
By buying this product you get 89 loyalty points
Reference : 7250
890,00 €tax incl.
741,67 € tax excl.
Shipping from France
Billing in France
Technical support in France
This kit allows the realization of a subwoofer resolutely "Audiophile" contains everything necessary for its implementation except carpentry.
Equipped with a Direct Servo technology and a common power, it is the indispensable complement to any system worthy of the name.
Focus on Direct-Servo technology:
  • The effects of thermal compression are eliminated during normal operation.
  • Enables greater efficiency that would normally require a more powerful amplifier.
  • The extension of the sub-basses can be achieved by using a low-mass pilot with an unmatched transient response.
  • Mechanical and thermal memory effects are reduced, which improves the transient response.
  • The effective value Q of 0.3 allows a much tighter and more precise control than the conventional models.
  • Maximum reduction of the bass feedback in the box.
Main Features :
  • HP: Driver DS1501 SLV 15 "(38 cm) high excursion with patented Direct Servo system
  • Materials: Bowl and cone Aluminum, rubber suspension
  • Amplifier 370W RMS Class A Servo B / Patented Controlled
  • Frequency response: 14 to 200Hz (-2dB @ 14Hz) with LFE inputs in A370PEQ3 / XLR2 / XLR3
  • Frequency response: 14 to 100Hz (-2dB @ 14Hz) with LINE IN inputs sur all models
  • 12 or 24dB / octave overlap slope (PEQ and XLR versions)
  • Filter (Low Pass): 25 - 100Hz
  • Filter (high pass): 20Hz 18dB / octave
  • Phase phase response
  • Phase adjustment from 0 to 180 degrees - continuous variation
  • (Q = 0.5), mean (Q = 0.7) and low (Q = 1.1)/ Li>
Contents of the kit:
  • Amplifier module: A370PEQ3 (370W RMS)
  • Speakers: DS 1505 15 "38 cm
  • Special subwoofer: 135 x 85 cm
  • Downloadable diagrams for the realization of a closed or low reflex box
Speaker Details:
  • Cone rigid-cone black aluminum anodized
  • High linear excursion - 1.2 "peak to peak (15mm go only) xmax
  • High mechanical excursion - 1.8 "peak-to-peak (xmech) to reduce the risk of tailgating
  • Low moving mass - 24 ohm ultra-thin sensor coil for controlled operation
  • Woven wires - prevents rattling during high excursion
  • Gold plated spring terminals for easy connection of seamless cables
DS1501
[Img-11721-left-thickbox_default]
[Img-11722-left-thickbox_default]
Amplifier A370PEQ3
[Img-11723-left-thickbox_default]
https://www.audiophonics.fr/images2/7250/7250_RYTHMIK_AUDIO_DS1505_DIY_KIT_2.jpg
Manufacturer's Datasheet (PDF)
Closed Scheme:
https://www.audiophonics.fr/images2/7250/7250_RYTHMIK_AUDIO_DS1505_DIY_KIT_3.jpg
Click to open document (PDF)
Bass Reflex Diagram:
https://www.audiophonics.fr/images2/7250/7250_RYTHMIK_AUDIO_DS1505_DIY_KIT_4.jpg
Clito open the document (PDF)
