Power Module A-19 2x3-20V LT1083
Module Alimentation A-19 2x3-20V LT1083
Reference : 4381
29,90 €tax incl.
24,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
  • Pre-assembled power supply board
  • LT1083 Controllers from 3 to 7A - TO-3P Format
  • Output voltage adjustable from +/- 3V to +/- 20V
  • Input voltage from 5 to 25V AC
  • Dimensions 107x58x53 mm
  • Capacitors: 2x2200μF / 35V + 2x470μF / 35V
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output voltage (V)14.0
Output voltage (V)6.0
Output voltage (V)20.0
Output voltage (V)19.0
Output voltage (V)4.0
Output voltage (V)7.0
Output voltage (V)10.0
Output voltage (V)5.0
Output voltage (V)13.0
Output voltage (V)16.0
Output voltage (V)17.0
Output voltage (V)18.0
Output voltage (V)15.0
Output voltage (V)3.0
Output voltage (V)8.0
Output voltage (V)9.0
Output voltage (V)11.0
Output current (A)NC
Input voltage (V)6.0
Input voltage (V)22.0
Input voltage (V)15.0
Input voltage (V)8.0
Input voltage (V)24.0
Input voltage (V)17.0
Input voltage (V)10.0
Input voltage (V)19.0
Input voltage (V)12.0
Input voltage (V)5.0
Input voltage (V)21.0
Input voltage (V)14.0
Input voltage (V)7.0
Input voltage (V)23.0
Input voltage (V)16.0
Input voltage (V)9.0
Input voltage (V)25.0
Input voltage (V)18.0
Input voltage (V)11.0
Input voltage (V)20.0
Input voltage (V)13.0
Power SupplyNC
5 reviews
fine power module
the module perfectly meets my expectations, is easy to set up and therefore keeps exactly the value, even under load.
despite the corona problems, I quickly had the power module at home.
perfect!
This review has been posted for Power Module A-19 2x3-20V LT1083
Great PSU
It works perfect!
This unit replace an old psu with the classic DC regulators LM317 / LM337.
Somebody here at reviews ask if can works as symmetrical + -v power supply. The answer is absolutely YES!
Works for me exactly as i was need. With AC 10V in every side, i have exactly + - 7.5 V OUTPUT!
The only thing you MUST do is to put a jumper from - to + exactly in the middle of the board (at output side), and grounding this point!
Also, no ripple, and imidiatly you can listen your difference from your old power supply!
Thank you Audiophonics for your products!
Great well build product for the money
Great well build product for the money. As far as I was able to measure ripple free output.
Good PSU
I checked the PSU at 18V output and results are very good, undetectable ripple and stable voltage.
bonjour,
je voulais savoir si cette alimentation est bien symétrique , + et - 3 à 20V
merci
