By buying this product you get 40 loyalty points
Open Source Streamer Raspberry 3 - Pi2Design 502DAC
Audiophonics is back with a new version of the RaspTouch, for experienced audiophiles. It includes a Raspberry Pi 3 and a 502DAC converter from Pi2Design. Supporting resolutions up to 24bit / 192kHz and offering an AES/EBU output, this RaspTouch offers optimal sound quality.
Supplied with a Micro SD card for the OS installation, there are many operating system options to choose from, depending on your preferences and needs.
Ready to use electronically, many software solutions exist to meet all your expectations: piCorePlayer, Max2Play, OpenElec...
Do you want to enjoy your music throughout your home? The Rasptouch offers you an efficient multiroom system, allowing you to stream your files on any turntable connected to your network and control them.
Thanks to the 502DAC PCM5122 converter you get a top-of-the-range dematerialized audio player, accepting resolutions up to 24bit / 192kHz and allowing the use of an AES/EBU output.
Optimised to give you a dynamic and accurate sound reproduction, this 502DAC is equipped with two NDK NZ2520SD clocks to ensure the lowest possible jitter and reduce phase noise.
In addition, a WM8804 chip converts the I2S stream to Pro-Audio AES/SPDIF at 24bit / 192kHz. The DAC also includes an LDO LT3042 and two Puls PE-65612 audio isolation transformers.
In the end, the system offers a complete connection: 4 USB 2.0 ports to connect the peripherals of your choice (USB key, hard disk...), 1 Ethernet port to enjoy the files stored on your network, a micro SD port for the OS, an HDMI output, a gold-plated RCA output, a Toslink output, an AES/EBU XLR format output and a BNC output with RCA adapter. This means you have a full range of connectors to meet all your needs and can take advantage of new integration possibilities in your audio systems.
Raspberry Pi
Version 3 Model B
502DAC
PCM5122
Design
Exclusive
Featuring a 7"touch screen, it allows you to easily and intuitively control your audio library via a graphical interface.
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and matt appearance give it a modern and contemporary design. A device that will fit perfectly into your high-end audio system.
Connectors : Inputs (RPI 3) | |
USB-A | 4x |
Ethernet RJ-45 | 1x |
Slot Micro SD | 1x |
Connectors : Outputs (502DAC) | |
Stereo RCA | 1x |
HDMI | 1x |
AES/EBU XLR | 1x |
BNC with RCA adapter | 1x |
Toslink | 1x |
Raspberry Pi 3 | |
SoC | Broadcom BCM2837 1.2GHz |
CPU | ARM Cortex A53 64bit 4 coeurs |
Wifi | 802.11 b/g/n |
Bluetooth | 4.1 |
LPDDR2 Memory | 1Go |
502DAC | |
Clocks | 2x NDK NZ2520SD |
Digital interface | Wolfson WM8804 |
LDO | LT3042 |
Sampling rate | 24bit 192kHz |
THD | -112dB |
Screen | 7" capacitive touch screen |
Screen resolution | 800 x 400px |
Color | Noir |
Case material | Aluminium and Plexiglass |
Dimensions | 200 x 95 x 230mm |
Power supply | Jack DC 5.5/2.1mm - 7.5V 2.9A (Included) |
Accessories | Jack 6.35mm to XLR Adapter BNC to RCA Adapter |
