ELECAUDIO DF-03 Braided Sheath Extensible Nylon (PET) 06-16mm
ELECAUDIO DF-03 Gaine Tressée Extensible Nylon (PET) 06-16mm
Braided sleeve made in PET (Polyethylene Terephthalate) mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique PET weaving allows easy and fast installation on bulky connectors of irregular shape.
3.7 / 5
Reference : 8252
1,30 €tax incl.
1,08 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Gaine vendue au mètre
ELECAUDIO DF-03
ThePETis braided from a 0.010 "monofilament of PolyEthylene Terephthalate for continuous use at temperatures between -40 ° C and 125 ° C . Its melting temperature is 210 ° C . It has good dielectric qualities as well as excellenttensile strength and angood elasticity . Its versatility is that it is used in fields as varied as the automotive industry, computer science, scuba diving, electronics, harnesses, audiovisual, and even some military applications.
WARNING :Depending on the diameter of the cable the effective length of the sheath can reduce up to 20%!
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø6mm1m
Ø8mm1.08m
Ø10mm1.15m
Ø12mm1.3m
Ø14mm1.7m
Ø16mm2m
Specifications:
  • For cable with a diameter between 06 and 16mm
  • StructurePolyethylene Terephthalate monofilament
  • High elasticity and excellent tensile strength
  • Temperature Resistance: -40 ° C and 125 ° C
  • Melting Temperature: 210 °
https://www.audiophonics.fr/images2/4911_GAINE_ELECAUDIO_DARK-GREY_4.jpg
https://www.audiophonics.fr/images2/8252/8252_elecaudio_gaine_2.jpg
https://www.audiophonics.fr/images2/8252/8252_elecaudio_gaine_1.png
ColorGray
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)16.0
7 reviews
Medium quality. I put it on a 3 m cable without much effort, but you have to be very gentle, because the individual threads like to pull out. Probably the price reflects the quality. Otherwise, as always, excellent in terms of packaging and delivery.
This review has been posted for ELECAUDIO DF-03 Braided Sheath Extensible Nylon (PET) 06-16mm
Assez fragile
Je n'ai pas d'expérience avec les gaines, c'est la première fois que j'en posais une, une fois trouvé "le coup" c'est assez facile à faire passer sur un cable de 16mm... * 6m. Pour le contre, elle semble très fragile et se troue facilement au moment de la pose. A voir comment elle va tenir sur la durée. Mais bel effet sur le câble.
Décevante
J’ai déjà monté plusieurs gaines mais celle-ci est vraiment galère. Elle s’effiloche et se troue très facilement. Elle est très souple et donc sans tenue .Sensible au moindre accrochage. Pour l’enfiler sur un câble de 3 mètres , bon courage !.
Très bon produit. Bonne fabrication. Facile à travailler.
Correspond à sa description.
Efficace
Après un léger souci avec la gaine qui était trouée au déballage je tiens à remercier audiophonics qui m’a remplacé le produit sous 48 h
J’ai pu terminer mon travail sans problème
Cette belle gaine est très efficace et protége bien le câble
Merci encore à Audiophonics pour leur très bons produits et surtout à la qualité de leur SAV
BRAVO
Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications....
