This grey braided nylon sheath will effectively cover your cables and give them greater mechanical resistance. This has an adjustable diameter from 6mm to 12mm.*
For easier mounting we recommend using cables up to 6mm in diameter with this sheath.
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
SHEATH LENGTH DEPENDING ON CABLE DIAMETER (FOR 1M CABLE) | |
Cable diameter | Sheath length required |
Ø6mm | 1m |
Ø8mm | 1.08m |
Ø10mm | 1.15m |
Ø12mm | 1.3m |
Sheath material | Braided Nylon |
Color | Gray |
Acceptable cable diameter | 6m to 12mm |
Sold by the meter | - |
