VIBRAPOD ISOLATORS MODEL2 Insulator / Vibration Absorbers (Set x4)
VIBRAPOD ISOLATORS MODEL2 Isolateur/Absorbeur Vibrations (Set x4)
4.5 / 5
Reference : 2652
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Absorbers Vibrapod x4
Vibrapod isolators (or absorbers) are designed to absorb vibrations that could be transmitted to your Hifi and video or other devices.
They protect the devices from vibrations that degrade the sound or video quality.
Because an absorber suitable for a 5kg CD player will not work for a 40kg amplifier, Vibrapod has designed 5 models to achieve optimum performance regardless of the weight of the device.
It is surely the absorbers which present the best efficiency / price ratio.
Your ears will certainly thank you ...
There are 5 models of Vibrapods depending on the weight of your components:
Model of VibrapodRecommended weight
(kg per Vibrapod)
Weight
(kg per Vibrapod)
Minimum weight of the device
for 4x Vibrapods
Model # 11.10.90 - 1.363.6 - 5.4
Model # 22.71.81 - 3.627.2 - 14.4
Model # 34.53.62 - 5.4414.4 - 21.7
Model # 47.26.35 - 8.1625.4 - 32.6
Model # 511.39.9 - 12.739.8 - 50.8
Dimensions:1.5cm high x 6.2cm in diameter.
For appliances with feet larger than 4.2cm, they can be placed directly on the dome of the Vibrapod
For appliances with feet with a diameter between 1.9 and 4cm, place them on the central island, Vibrapod upside down (photo2)
For appliances on points, add a tailstock with a minimum diameter of 1.9cm.
componentand feet
In some cases, when the bottom of the appliance is irregular,e the original feet are too small or the appliance is heated, it is advisable to use a "sandwich" mounting
You should then place your device on a shelf, which itself will rest on Vibrapod.
Remember to include the weight of the shelf when choosing the Vibrapods model.
Because of their vinyl design, it is possible that the Vibrapods leave some traces on the smooth surfaces.
Diameter (mm)62.0
MaterialRubber
Height15.0
4 reviews
Extra.
Utilisés pour les placer sous une platine CD.
Une fois en place ils s'avère très souples, efficace pour supprimer les effets résonances et de ronflements.
Apportent par la même occasion un petit plus pour le rendu sonore, meilleur précision au niveau de médiums aigus.
This review has been posted for VIBRAPOD ISOLATORS MODEL2 Insulator / Vibration Absorbers (Set x4)
léger mieux que sans
pour le prix un léger gain dans le medium aigu sur preamp et source CD
Personnellement je n'entends pas de différence sur mon système audio qui n'est pas bas de gamme. Peut-être que mon oreille n'est pas assez fine, soit... par contre le plastique est surement de mauvaise qualité, il reste ratatiné après avoir passé quelque temps sous un appareil hfi de type lecteur cd. Je doute qu'il garde ses propriétés isolatrices, donc à mon avis ce n'est pas un très bon produit. C'est un gadget parmi autres...
Alors, gadget ou vraiment utile, les Vibrapods et les isolateurs ?
4 Vibrapods Mod 2 achetés, placés sous mon lecteur CD, dont je connais bien la sonorité.
Première écoute : Tiens, il sonne bien aujourd'hui, mon ensemble. J'ai pris LE bon CD, avec une bonne qualité d'enregistrement me dis-je !
Je les enlève, pour comparer et ne pas être dans l'effet placébo.
Mince, mais où sont passés les micro-détails. Et la scène sonore : moins aérée !
Différence très nette.
En fait, les Vibrapods jouent vraiment sur la restitution de l'ambiance globale, meilleure perception du lieu d'enregistrement. On perçoit mieux la salle, et les résonances.
Sur un CD, des cymbales résonnent vaguement en arrière plan sans les Vibrapods, et elles viennent se positionner clairement dans l'espace, avec une perception détaillée de leur timbre.
Tels sont les exemples d'améliorations.
A tel point que même ma femme, néophyte et qui ne se torture pas la tête à chercher le rendu du petit détail en a clairement perçu la différence.
Valeur sûre ! Très sûre !!!
 (5)
