SOUNDCARE SUPERSPIKES FOOT Adhesive Damping Feet 32x17mm (Set x3)
SOUNDCARE SUPERSPIKES Adhesive - Pieds Adhesifs (Set x3)
4.4 / 5
Reference : 1475
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Soundcare SuperSpikes
Feet Superspike Soundcare
The Soundcare®SuperSpike spikes are high end support for speakers and hi-fi equipment. Their specific design eliminates the problem most frequently encountered in high fidelity audio: damaged surfaces. These spikes allow moving your audio equipment without scratching the floor.
When the weight of your Hi-Fi components is concentrated on a small area, the pressure per cm² increases considerably providing better contact with its support. The result is an improved sound stage through better control of the register bass (mechanical absorbtion of vibration noise).
A Superspike tip loaded with a weight of 12.5kg produces a pressure 6200Kg per cm² at its end, thus reducing vibration and limiting the transmission of unwanted vibrations to subsequent parts of your audio installation.
For the best sound reproduction, reducing distortion and better control of low frequencies, a unique combination of materials was selected after listening and measuring. During their development these spikes were tested by a panel of engineers, musicians and audiophiles with tremendous results!
These spikes are especially recommended for insulating Subwoofers.
TypeSpikes
Diameter (mm)32mm
MaterialsPolymere foam
Package Contents
Soundcare SUPERSPIKESx3
Diameter (mm)32.0
MaterialNon-Metal
Height17.0
10 reviews
Mediocre qualité
Matériel à fuir . Il y a beaucoup mieux pour le même prix.
This review has been posted for SOUNDCARE SUPERSPIKES FOOT Adhesive Damping Feet 32x17mm (Set x3)
soundcare version sans filetage
Je suis très content de mon achat. Avec ma platine Atoll cd50 cela marche à merveille. Le son est précis sans être froid comme parfois avec le cd, avec un côte feutré et on peut même dire moelleux (cela provient peut-être aussi de mon ampli). En tout les cas le résultat est très supérieur qu'avec des pieds beaucoup plus chers que j'ai eu l'occasion d'essayer auparavant. Merci Audiophonics pour le prix imbattable et pour la livraison parfaite.
pointes
excellent produit, très bon découplage et mise en place facile et plus secure que des pointes classiques.
Efficaces
J'utilises déjà des superspikes sous mes pieds d'enceintes , avec succés (précisions accrue, scene sonore plus précise, et basses plus franches)
J'ai commandé cette version pour mon caisson DIY. Beaucoup moins de vibrations, c'est plus sec et rapide.
Pas l’impression de perdre d'impact ou de niveau, à confirmer avec le temps.
J'aimerai bien les comparer sur un sub à un Sub Dude, ce genre de chose, mais audiophonics n'en propose pas
super spikes
Si vous recherchez du "pas cher et pratique"
c'est tout bon! Si vous recherchez un
veritable gain.....c'est nettement plus cher......
