Brass Spikes M8 Gold (Set x4)
Pointes de Découplage M8 Laiton Dorées (Set x4)
Reference : 2943
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
coupling points M8 Audiophile
Spikes M8 (x4 set)
Coupling or uncoupling? Although generally very widespread in the Audiophile environment, the decoupling term is often misused: the spikes are not in the true sense of de-couplers but couplers. The action in the physical sense to connect two elements with spikes allows energy to flow freely between them, transferring vibrations to the last link in the chain. It is easy to understand that a rigid contact surface even reduced transmit all the energy that is issued.
Spikes operate as mechanical amplifiers made by concentrating all the mass of the product supported on a very small contact surface facilitating the stability and the flow of energy to the speaker holder. If the carrier is sufficiently heavy and inert, the vibrational energy is removed. The chamber vibrates less, the distortion disappears, the bass sound is clearer, more précis.Si the support is flexible and lightweight, it captures the vibration, sounds and degrades the sound rendering.
Ideal for mounting in heavy speaker
High fidelity decoupling brass spikes
Insert diameter12mm
Adjustable height27-40mm
Weight90g
ThreadM8
Package Contents
Spikes M8 Brassx4
Diameter (mm)12.0
MaterialMetal
Height30.0
Height27.0
Height40.0
Height35.0
Trés bonnes pointes
Pointes trés efficaces, excellent résultat.
This review has been posted for Brass Spikes M8 Gold (Set x4)
