Potentiometer ALPS RK09 10k 2 way + Switch 3A
Potentiomètre ALPS RK09 10k 2 voies + Interrupteur 3A
4.0 / 5
Reference : 5806
8,50 €tax incl.
7,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
Potentiometer ALPS RK0971221Z05 10k 2 way + Switch
Logarithmic potentiometer with 3A switch
Number of resistor elementsDual-unit
Mounting directionHorizontal type
Shaft typesFlat
Length of the shaft15mm
Center detentWithout
Total resistance10kΩ
Resistance type3B
Operating temperature range-20 ℃ to + 70 ℃
Electrical PerformanceTotal resistance tolerance± 20%
Rated power0.05W
Maximum operating voltage50V AC, 10V DC
Maximum attenuation80dB min.
Gang error-40dB to 0dB 3dB max.
Insulation resistance100MΩ min. 250V DC
Voltage proof300V AC for 1 minute
Mechanical PerformanceTotal rotational angle300 ± 5 °
Rotational torque2 to 25mN · m
Stopper strength0.5N · m
Push-pull strength100N max.
Vibration10 to 55 to 10Hz / min., The amplitude is 1.5mm for all the frequencies, in the 3 direction of X, Y and Z and for 2 hours respectively
Solder heat resistanceManual soldering350 ℃ max. 3s max.
Dip soldering260 ± 5 ℃, 5 ± 1 s
durabilityOperating life15,000 cycles
Environmental testingCold-30 ± 2 ℃ for 96h
Dry heat70 ± 2 ℃ for 96h
Damp heat40 ± 2 ℃, 90 to 95% RH for 96h
SpecificationsContact arrangementSPST
Changeover angle50 ° max.
Operation torque50mN · m max.
Ratings3A 16V DC
Contact resistance (Initial period / After operating life)100mΩ / 200mΩ
Operating life10,000 cycles min.
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_1.jpg
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_2.jpg
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_3.jpg
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_4.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_5.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_6.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_7.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_8.GIF
Channel2 (Stereo)
Resistance (Ohm)10000.0
Tolerance (%)20.0
FOnctionne bien
Il y a ambiguité sur le site : on ne sait pas s'il est avec ou sans inter. Finalement le modèle reçu est avec interrupteur.
This review has been posted for Potentiometer ALPS RK09 10k 2 way + Switch 3A
