Kit cable DIY Audiophonics Sector PCG5 Shielded 3x4mm² 1.00m
Kit câble DIY Audiophonics Secteur PCG5 Blindé 3x4mm² 1.00m
4.6 / 5
Reference : 3717
40,00 €tax incl.
33,33 € tax excl.
Shipping from France
Billing in France
Technical support in France
Kit cable mains DIY ELECAUDIO PCG5 - 1.0 m
Audiophonics markets kit cables for ease of use.
All necessary components are supplied to build a complete high end power cable
This kit includes:
  • 1.0 m WM-AUDIO TORNADO Double Shielded Shield Cable 3x4.0mm²
  • 1 x ELECAUDIO PI-34GC Power socket IEC Crystal Gold 24K 5μ Ø16.5mm
  • 1 x ELECAUDIO PS-34GC Socket Schuko Crystal Gold 24K 5μ Ø16.5mm
  • 1.5mx Viablue Braided sheath 05-14mm Army
  • ELECAUDIO EC-4 OCC copper tips For cable 4,00mm²
Result when mounted:
https://www.audiophonics.fr/images2/3717/3717_KITPCG5_CLEAR_1.jpg
https://www.audiophonics.fr/images2/3717/3717_KITPCG5_CLEAR_2.jpg
If you want this cable mounted, we offer a mounting package.
Please go to
the following cardto take advantage of our offer:
https://www.audiophonics.fr/images2/5188/5188_CABLE_ASSEMBLY_5.jpg
Tornado shielded cable 3x4mm²
This3x4mm² cross-section with double shielding against electromagnetic interference
This shielding consists of a metal strip in addition to a copper braid.
It will guarantee a fine and detailed sound reproduction.
  • Outside diameter: 12.9 mm
  • Section: 3x4mm²
  • Double shielding strap + copper braid
Cable also sold by meter
IEC connector specifications :
  • IEC 3 plugs Screw-in contacts
  • Double Plating:Or 24k 3μ
  • Maximum Driver Section:16mm²(4.5mm of Diameter)
  • Maximum Cable Diameter: 16.5mm
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 80mm
  • Diameter: 38mm
  • Weight: 60g
    https://www.audiophonics.fr/images2/6585/6585_ELECAUDIOPI24GC_1.jpg
    IEC connector also sold individually
    Connector specifications schuko :
    • Connectors Schuko 3 Screw Connectors
    • Plating:Or 24k 3μ
    • Overall Length: 89 mm
    • Diameter: 38 mm
    • Weight: 75 g
    https://www.audiophonics.fr/images2/6584/6584_ELECAUDIOPS24GC_1.jpg
    Schuko connector also sold individually
    Cable schematics:
    https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
8 reviews
Très bon rapport qualité prix
J'ai déjà laissé un avis sur le câble WM Audio tornado qui a un excellent rapport qualité prix mais qui en revanche n'est pas flexible du tout. Le kit est très bien fait et facile à monter en suivant le tuto sur le blog audiophonics. En revanche, en suivant les indications "N" et "L" sur les prises schuko et IEC Elecaudio fournies, j'ai constaté que la phase se retrouvait du mauvais côté. Ce qui n'est pas méchant quand on a une barrette shucko qui peut s"inverser.
Petite remarque : Le kit laisse à penser qu'il y a 10 cosses fournies mais il n'y en a que 6. Ce qui est suffisant. Par ailleurs, 2 bouts de gaine thermo sont fournies ce qui n'est pas stipulé. Donc, inutile d'en commander en plus.
This review has been posted for Kit cable DIY Audiophonics Sector PCG5 Shielded 3x4mm² 1.00m
très bon câble .
Un peu rigide peut être , mais bon vu la section c'est normal !
Montage simple .
Envoi rapide , tout est bien emballé séparément .
Merci AUDIOPHONICS pour votre sérieux .
Tres bon cable
Très bon câble, livraison rapide très bien emballé.
Montage impeccable, il suffit de prendre son temps.
Excellent rapport qualité/prix.
Juste un tout petit bémol, la gaine tissu est un peu fragile.
Excellent rapport qualité prix
Esthètique superbe et montage facile. Pas de perte de dynamique. Son neutre, assez doux. Pas de dégradation du son contrairement à de nombreux câbles secteurs.
Arnaud.R
Une fois bien monté, ce kit apporte indéniablement un plus dans le message sonore. La scène s'agrandie, l'articulation globale du message est bien meilleure.
Mon ampli/DAC Hegel peut s'exprimer, enfin pleinement.
Honnêtement pour le prix, une totale réussite.
