Kit cable DIY Audiophonics Sector PCG5 Shielded 3x4mm² 1.50m
Kit câble DIY Audiophonics Secteur PCG5 Blindé 3x4mm² 1.50m
Reference : 3718
45,00 €tax incl.
37,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Kit cable mains DIY ELECAUDIO PCG5 - 1.5 m
Audiophonics markets kit cables for ease of use.
All necessary components are supplied to build a complete high end power cable
This kit includes:
  • 1.5 m WM-AUDIO TORNADO Double Shielded Shielding Cable 3x4.0mm²
  • 1 x ELECAUDIO PI-34GC Power socket IEC Crystal Gold 24K 5μ Ø16.5mm
  • 1 x ELECAUDIO PS-34GC Socket Schuko Crystal Gold 24K 5μ Ø16.5mm
  • 2 mx Viablue Braided sheath 05-14mm Army
  • ELECAUDIO EC-4 OCC copper tips For cable 4,00mm²
Result when mounted:
https://www.audiophonics.fr/images2/3717/3717_KITPCG5_CLEAR_1.jpg
https://www.audiophonics.fr/images2/3717/3717_KITPCG5_CLEAR_2.jpg
If you want this cable mounted, we offer a mounting package.
Please go to
the following cardto take advantage of our offer:
https://www.audiophonics.fr/images2/5188/5188_CABLE_ASSEMBLY_5.jpg
Tornado shielded cable 3x4mm²
This3x4mm² cross-section with double shielding against electromagnetic interference
This shielding consists of a metal strip in addition to a copper braid.
It will guarantee a fine and detailed sound reproduction.
  • Outside diameter: 12.9 mm
  • Section: 3x4mm²
  • Double shielding strap + copper braid
Cable also sold by meter
IEC connector specifications :
  • IEC 3 plugs Screw-in contacts
  • Double Plating:Or 24k 3μ
  • Maximum Driver Section:16mm²(4.5mm of Diameter)
  • Maximum Cable Diameter: 16.5mm
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 80mm
  • Diameter: 38mm
  • Weight: 60g
    https://www.audiophonics.fr/images2/6585/6585_ELECAUDIOPI24GC_1.jpg
    IEC connector also sold individually
    Connector specifications schuko :
    • Connectors Schuko 3 Screw Connectors
    • Plating:Or 24k 3μ
    • Overall Length: 89 mm
    • Diameter: 38 mm
    • Weight: 75 g
    https://www.audiophonics.fr/images2/6584/6584_ELECAUDIOPS24GC_1.jpg
    Schuko connector also sold individually
    Cable schematics:
    https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Bonjour, je viens d'assembler ce kit et après quelques jours d'utilisation je le recommande. Il est branché sur mon Little Dot mkII et le gain de musicalité est incontestable : du punch combiné à une absence d'agressivité, une main de fer dans un gant de velour. Il ne reste "que" le plaisir de la musique. Pour trouver un défaut, j'évoquerai le manque de souplesse du câble mais une fois connecté il prend sa place et on n'en parle plus.
This review has been posted for Kit cable DIY Audiophonics Sector PCG5 Shielded 3x4mm² 1.50m
