Elfidelity AXF-100 External USB Power Filter for PC
Elfidelity AXF-101 filtre alimentation USB Externe pour PC
Reference : 9057
49,00 €tax incl.
40,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Elfidelity AXF-101 External USB Power Supply Filter for PC
The AXF-101 is the perfect companion for anyone using a PC or HTPC as a dematerialized source with a USB (DAC) converter.
Based on very high-end components and connectivity, it will clean the USB port of the noise generated by the switched-mode power supply while allowing you to inject if desired 5V "clean" from an external source (Battery, Power linear, etc.).
Specifications:
  • Current Rating: 5A
  • Maximum Power: 25W
  • Automatic switching speed: <5ms
  • Ripple Factor: <1Hz
  • Japanese Capacitors
  • TDK armored inductors
  • Relais Takamisawa Japanese
Characteristics :
  • Status LEDs
  • Comes with USB A to B cable
  • Comes with USB power cable to Jack DC 2.1 and transformer 5 V 2A
  • Dimensions: 95 x 75 x 25 mm
  • Weight: 350 g
