SUPTRONICS X600 Module HAT S/PDIF / HDMI 5.1 Downmix / Sata for Raspberry Pi
ST 600 HAT Module HDMI to S/PDIF & Stereo RCA analogue 5.1 1080p
Reference : 10249
44,90 €tax incl.
37,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
The ST600 is the ideal module for users of multimedia solutions that allow the playback of high-definition audio files as well as multi-channel streams from films.
This solution lets you retrieve audio streams from the HDMI digital output to convert them to digital stereo or digital SPDIF analog audio requirements for external decoding.
This extremely flexible solution also integrates a SATA port to simply add an expanded storage capacity to the PI.
Please note, however, that this product is reserved for experienced users with linux databases, instructions for running the various modules will be posted on the forum quickly.
Features:
  • GPIO for direct connection to Raspberry Pi
  • Input voltage: 6V to 20V DC converts to 5V 3A via step-down DC / DC regulator to power the Raspberry Pi
  • Recommended Power Supply: 12V 2A (not supplied), DC Jack 5.5 / 2.1mm (+ center)
  • SATA connector
  • Input / Output HDMI 1.4
  • USB 2.0 port
  • Outputs: RCA Stereo, 3.5mm Stereo Line Level Jack, S / PDIF Coaxial, Toslink
  • (Dolby, DTS and AC3 not Dolby TrueHD, DTS-HD Master), 2-way (stereo RCA output) and S / Pdif (coaxial and toslink) Audio etc ..)
  • IR receiver (38kHz) NEC code for remote control (GPIO 18)
  • Dimensions: 85x56mm (same dimensions as PI)
  • USB adapter, HDMI adapter, 4 spacers (M3x20mm) and 8 nylon screws (M3x6mm) supplied
  • Compatibility RASBIAN
InputSATA
InputHDMI
InputGPIO
OutputCoaxial SPDIF
OutputOptical Toslink
OutputJack 3.5mm
OutputHDMI
DAC / ADC ChipNC
Max sampling rateNC
mm
en ce qui concerne le module il est super je vais en prendre un 2 e mais trouve pas un bon boitier
This review has been posted for SUPTRONICS X600 Module HAT S/PDIF / HDMI 5.1 Downmix / Sata for Raspberry Pi
