NEOTECH DG-201 RCA Plug Central pin OFC Ø10.5mm (Set x4)
NEOTECH DG-201 RCA Plug Central pin OFC Ø 10.6mm (Set x4)
4.8 / 5
Reference : 11928
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
These RCA connectors NEOTECH DG-201 have the particularity of accepting large diameter modulation cable (10.5mm). They are thus particularly compatible and designed for the following cable ranges:
This large diameter RCA connectorthe design of high-end cables thanks to its central gold-plated OFC copper pin. It allows to keep a consistent continuity of materials.
This RCA connector will therefore be preferred with OFC, OHFC, OFC 6n, Litz and obviously OCC copper modulation cables, allowing a high percentage of high IACS conductivity.
Insulation is a truly important factor in improving signal transmission capabilities. This is why PTFE has been chosen on these RCA connectors, the latter providing excellent electrical insulation and low electrical permittivity.
Features:
  • RCA male with large internal diameter acceptable: 10.5mm
  • CNC machining (CNC machine)
  • PTFE Insulation
  • Excellent conductivity with central pin of copper hot spot OFC
  • Brass external body and cold spot
  • Plated 24K Gold
  • Dielectric Insulation: PTFE
  • Clamping screw
  • Sold in lots of 4
Dimensions and weight:
  • Outside diameter 15mm
  • total length: 60mm
Max cable diameter (mm)10.5
Mounting typeTo weld
ConnecticMale
5 reviews
Neotech
Very solid plugs, NEOTECH NEI-2001 Interconnect Cable UP-OCC Silver cable fits nicely inside which some plugs can't manage
This review has been posted for NEOTECH DG-201 RCA Plug Central pin OFC Ø10.5mm (Set x4)
Câble audio hi-fi
Tres bonne qualité du produit pour réaliser un câble de qualité audiophile.
Belle Qualité
Belle qualité de fabrication pour ces connecteurs RCA. Associés au câble NEOTECH NEI-3001 MKIII, d'un diamètre de 10 mm, je me suis fabriqué un câble hyper musical. Services Audiophonic parfaits (Merci pour les conseils de montage)
 (3)
Great performance at reasonable price
With a recommendation from my audiophile friend, I purchased DG-201s to replace RCA plugs from a well know brand that costs almost 4 times as much. I was dumbfounded by how different the sound was and how much it improved to my liking. They are natural and a bit warmer side of neutral. Sound is musical and very enjoyable but also meets the audiophile requirements . Highly recommended!
Raffinée
Lourdes, imposantes et parfaitement finies ces DG 201 Neotech trônent avec élégance avec leurs câbles 3220 Neotech sur l'ampli à tubes dont les RCA Elecaudio TE-ER 6S NG sont à l'avant du chassis. L'ensemble produit un raffinement musical de tout premier ordre avec une précision inégalée et, plus important encore, l'absence de fatigue auditive quel que soit le niveau d'écoute. C'est la première fois que mes enceintes à haut rendement (98dB) transcrivent un message avec autant de matière, aussi précis et volumineux. Une belle association en tous cas.
 (4)
