FURUTECH FP-901 (R) RCA Headers Pure Copper Plated Rhodium (The Pair)
FURUTECH FP-901R Embases RCA Cuivre pur plaqué Rhodium (la paire)
4.7 / 5
By buying this product you get 36 loyalty points
Reference : 7333
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
These Furutech bases in pure copper machined in the mass and Rhodium plated offer a record conductivity level.
The vast majority of audio connectors are made from brass or bronze / phosphor alloy with a conductivity typically less than 28% IACS (International Annealed Copper Standard).
By way of comparison, the high purity copper (OFC) used in most interconnection cables at a conductivity rate of 100% IACS.
InBecause of the use of these "low" conductivity alloys, the majority of even expensive RCA sockets tend to decrease the performance of the cables to which they connect.
Characteristics :
  • Contacts of pure copper cut in the mass
  • Alpha Treatment
  • Rhodium Plating
  • Insulation: PTFE
  • Welding
  • Max. Connector Diameter: 16 mm
  • Connector Shell Size: 19.5 mm
  • Overall length: 39 mm
  • Max Panel Thickness: 7.3 mm
https://www.audiophonics.fr/images2/7333/7333_furutech_FP-901R-Embases%20RCA_thumbs.png
https://www.audiophonics.fr/images2/7333/7333_furutech_FP-901R-Embases%20RCA_1.jpg
https://www.audiophonics.fr/images2/7333/7333_FURUTECH_FP-901-R_2.jpg
Mounting typeTo weld
Max panel thickness (mm)7.3
3 reviews
Mise en oeuvre
Dans mon cas il s'agissait de changer 2 embases défectueuses sur une platine TD.Au chapitre des regrets:Pour le prix:PAS DE NOTICE DE CONSEILS DE MISE EN OEUVRE (Température maxi de chauffage,etc..).Les connections sont trop rapprochées pour pouvoir souder-dans ma configuration.)
La construction Furutech est bonne,les cordons de liaison s'adaptent parfaitement.
This review has been posted for FURUTECH FP-901 (R) RCA Headers Pure Copper Plated Rhodium (The Pair)
Hors norme
C'est cher. Tout d'abord elles sont très bien fabriquées, la finition est parfaite.
Le résultat à l'écoute est là sur du bon matériel. Neutralité, qualité générale, propreté, dynamique, spatialisation. En particulier sur les médiums je trouve l'apport important.
Il faut oser faire le saut pour acheter un tel produit, vouloir "la cerise sur le gâteau" pour aller au bout d'un matériel.
qualité exceptionnelle
Montage facile à l'aide de gabarit en puzzle.
Superbe qualité de finition.
Rendu superbe sur ampli.
La qualité se paye.
Validation totale!!
