FIIO Kilimanjaro E11 Amplifier Mobile headphones on battery
FIIO Kilimanjaro E11 Amplificateur Casque mobile sur batterie
Reference : 8178
59,00 €tax incl.
49,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
The E11 is a nomadic power amplifier design and very convenient to carry thanks to its small size.
This nomadic amplifier is compatible with headphones from 16 to 150 ohms, and offers a high output level of 180 mW under 32 ohms.
Its small size, comfortable power and ease of use make it a "must have" for anyone who finds their readers too "just".
Characteristics:
  • Supported Headphone Impedance: 16 - 150 ohms
  • Output power:> 180 mW at 32 ohms
  • Total harmonic distortion (THD): 0.004% (1 KHz)
  • Output impedance: <0.3 ohms
  • Frequency response: 10 Hz - 300 KHz
  • Signal to noise ratio:> 106 dB
  • Input Sensitivity: 965 mV (Voltage High / Gain Low) / 560 mV (Voltage High / Gain High)
  • MAX input level:> 8 Vrms
  • Crosstalk:> 59 dB at 1 KHz
  • Channel Balance: <0.5 dB
  • Gain:> 8 dB
  • Bass boost:> 4 dB (Bass 1)
  • Output voltage MAX:> 6.8 Vp-p (Voltage High)
  • MAX output current:> 75 mA
  • 1 mini-jack input 3.5 mm
  • 1 mini jack output 3.5 mm
  • 1 mini-USB port (battery charging)
  • ALPS volume potentiometer
  • Bass boost (2 levels)
  • C gain control (2 levels)
  • 2 operating voltage levels
  • Supply voltage: USB 5V / 500mA
  • Battery Type: BL-5B
  • Battery capacity:> 800 mAh
  • Battery life: Up to 10 hours
  • Charging time: <210 minutes
  • Weight: 65 g
  • Dimensions (W x H x D): 92.5 x 13.4 x 54.2 mm
  • Accessories:
    • USB to mini-USB cable
    • Elastic band Fiio x2
    • 3.5 mm angled mini-jack cable to mini-jack 3.5 mm
    • User Manual
Review Head Fonia.com
https://www.audiophonics.fr/images2/8178/8178_fiio_E11_kilimanjaro_01.jpg
https://www.audiophonics.fr/images2/8178/8178_fiio_E11_kilimanjaro_3.jpg
Illustrations: accessories sold separately
https://www.audiophonics.fr/images2/8178/8178_fiio_E11_kilimanjaro_1.jpg
nter ">
https://www.audiophonics.fr/images2/8178/8178_fiio_E11_kilimanjaro_2.jpg
J'ai un smartphone Huawei et la sortie casque est tout juste lamentable et je pèse mes mots. Ayant des bw c5, j'ai donc décidé de le prendre et j'en suis pas déçu. Malgré le fait qu'il faut que je le mets à fond pour tirer parti de mes c5, je dois dire qu'il me sauve la vie. !
This review has been posted for FIIO Kilimanjaro E11 Amplifier Mobile headphones on battery
