Power on and delay softstart board and protection for amplifier
Power on and delay softstart board for amplifier
4.9 / 5
Reference : 10225
29,90 €tax incl.
24,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
This card is used to control the ignition of an amplifier, it performs the function stand-by, soft-start, delay and thermal protection.
It limits the current supply through the supply capacitors and the transformer to ignition.
This card does not remove the ignition pads, in this case it is an HP timeout card you need.
This card plugs directly into the 220V input.
If no load is connected, you can find 220V output (capacitor in series).
When you activate the softstart this powers your amplifier through the thermistors.
After a second the 2nd relay switches on and connects the output directly to the 220V.
A residual voltage may remain at the output in the OFF position. If this is the case, then you must remove the yellow capacitor between the 2 relays.
Module wiring
Module softstart de commande / temporisation et protection pour amplificateur
The LED can be installed in either D1 or D2. In the first case (D1), it will be switched off when the module is switched on. Conversely, in the second case (D2), the LED will be lit when the module is also lit.
Thermocontacts are optional and may or may not be fitted. They provide additional thermal protection by switching off the module when it reaches 75°C.
Characteristics :
  • Maximum relay current: 30A
  • Operational module up to 1000W max.
  • 1 sec. about
  • Thermal protection triggered at 75 ° C (temperature probes and wiring provided)
  • Switching by fugitive push-button low amperage
  • Thermistors of current limitation (soft-start)
  • Spacing: 83.5mm, 69mm
  • Spacers, screws, LEDs, terminals and wiring provided
  • Dimensions of the card: 92x77.5x30mm
  • Weight: 230g
12 reviews
Très bon produit
Circuit de bonne qualité. Le vernis pourrait être un peu plus costaud mais le reste est nickel. Il y a 4 CTNs 16D20. 2 en parallèle 2x et chaque paire est en ensuite en série. Cela fait donc une résistance de 16 ohms au total en série sur le secteur au démarrage. il y a 2 relais. Quand on met sous tension, le circuit est à l’arrêt. Si on appuie sur un poussoir (monostable), le premier relais tire et met sous tension avec les CTNs en série. 2s après le second relais court-circuite les CTNs. Une led bicolore indique le stand by (éteint) et la mise sous tension.
This review has been posted for Power on and delay softstart board and protection for amplifier
Molta buona
Per un mio progetto da anni cercavo una scheda del genere ,fino a qualche giorno fa non conoscevo questo sito ,appena l ho visto l ho acquistato subito. Alla ricezione della merce mi è arrivata danneggiata,ma il supporto clienti ha subito risolto la problematica è posso confermare che la professionalità e competenza è alti livelli. Per la scheda veramente ottima.
WONDOM AA-AB41122 Linear Power Supply board 100V 30A 35000uF
very good....
very good.....
very good......
