AURALiC ARIES MINI HiFi Streamer ES9018K2M DAC WiFi DLNA AirPlay 32bit 384Khz White
AURALiC Aries Mini Hi-Fi Streamer ES9018K2M 32bit 384Khz White
The Auralic Aries Mini is a complete and powerful network drive, integrated into a compact and attractive housing. It will allow you to upgrade your audio system to provide more advanced connectivity and enjoy your audio files more simply and quickly.
Reference : 10740
499,00 €tax incl.
415,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Auralic Aries Mini
Auralic Aries Mini DAP Sédentaire et Lecteur Réseau ES9018K2M 32bit 384kHz Blanc
DAC ES9018K2M & Powerful CPU
The heart of the Aries Mini is its proprietary Auralic Tesla Quad ARM A9 processor running at 1GHz. This one, in charge of data processing and associated with the Auralic Lightning DS OpenHome interface (iOS 8 compatible), allows fast, smooth and extremely efficient navigation and reading.
The digital-to-analog conversion part is handled by a DAC ESS ES9018K2M chip supporting high sampling rates up to 32bit 384kHz in PCM and up to DSD256. This chip uses the 32bit HyperStream architecture and Time Domain Jitter Eliminator technology, giving it a nice dynamic, THD+N of -120dB while significantly reducing jitter.
Connectivity
One of the strengths of the Aries Mini is undoubtedly its connectivity. Indeed, it offers an RJ45 Gigabit port as well as WiFi support, to allow you to access files stored on devices on your local network (computer, NAS, smartphone...). There is also a space to accommodate a 2.5" hard disk (not provided).
The device is also compatible with many streaming services such as Qobuz, Spotify Connect, Tidal and Internet radios. This way you can enjoy your favorite service to listen to your music simply. In addition, the Aries Mini is compatible with DLNA/UPnP and AirPlay protocols to allow you to easily stream your audio files from your smartphone.
On the output side, there is a S/PDIF Coaxial connector, Toslink Optics, stereo RCA and a USB-B 2.0 output to connect an external DAC and give it the advanced connectivity of the Aries Mini.
The performance of the Aries Mini can be increased by using a Auralic PSU optional line power supply. The latter provides better stability of the sound stage and refinement of harmonics in the midrange and treble.
Video review of the Auralic Aries Mini by The Hans Beekhuyzen Channel
Auralic Aries Mini review by Qobuz
" The Auralic Aries Mini streamer is a modern device that offers a wide range of settings and reading capabilities, resulting in very good sound quality on its analog outputs. "
Test du Auralic Aries Mini par Qobuz
Technical charcateristics
Product typeStreamer
Inputs1x RJ45 Ethernet Gigabit
WiFi Dual Band
1x 2.5" Hard Drive Slot (not included)
OutputsUSB-A 2.0 for audio DAC
1x S/PDIF Coaxial
1x Optical Toslink
1x Stereo RCA
Supported sampling ratesUSB : up to 32bit 384kHz
Coaxial : up to 24bit 192kHz
Optical : up to 24bit 96kHz
Compatible streaming serviceQobuz
Spotify Connect
Tidal
Radios internet
AirPlay
Software interfaceAuralic Lightning DS OpenHome, iOS 8 compatible
Compatible media serversMinimserver
Twonky Asset UPnP
Jriver
DLNA/UPnP
AirPlay
Supported audio formatsAAC, AIFF, ALAC, APE, DIFF, DSF, FLAC, MP3, OGG, WAV, WV, WMA
Power supplyVia Jack DC 5.5/2.5mm connector
Max consumption10W
Dimensions135 x 135 x 28mm
Weight500g
InputRJ45
InputWiFi
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
Max sampling rateDSD256
Max sampling rate384kHz
ColorOther
ColorWhite
The Auralic Aries Mini is a complete and powerful network drive, integrated into a compact and attractive housing. It will allow you to upgrade...
