DYNAVOX Wall Plate 2 Speaker Terminals 24k Gold Plated
DYNAVOX Plaque Murale 2 Borniers HP Plaqués Or 24k
4.5 / 5
Reference : 4746
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Brushed stainless steel plate with matte finish to be embedded in a wall with 2 mounting screws provided. Equipped with a pair of 24k gold plated HP terminals compatible with large section cables and banana plugs. Color-coded and silk-screened identification of left and right channels.
Specifications :
  • Brushed stainless steel plate
  • High quality 24k gold plated speaker terminals
  • Screw-in contacts or use of banana plugs
  • Compatible with cables up to 5mm in diameter
  • Plate dimensions: 85*85mm
  • Mounting holes spacing: 62mm
  • Plate thickness: 4.5mm
  • Internal terminal depth: 16mm
  • Weight: 100g
  • Fixing screws supplied
https://www.audiophonics.fr/images2/4746_PLAQUE-MURALE-2HP_1.jpg
https://www.audiophonics.fr/images2/4746_PLAQUE-MURALE-2HP_2.jpg
https://www.audiophonics.fr/images2/4746_PLAQUE-MURALE-2HP_4.jpg
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
2 reviews
De bonne facture. Pas de chevilles fournie avec juste des vis mais avec têtes plates
This review has been posted for DYNAVOX Wall Plate 2 Speaker Terminals 24k Gold Plated
livraison rapide produit de bonne qualité pas de soucis lors de la pose mais j'ai du mettre d'autre vis que celle fournit pour faire tenir le tout dans des chevilles dans la cloison les borniers sont egalement de bonne facture;.
